EatLag Posted March 20, 2014 Report Share Posted March 20, 2014 Hey guys, i know sweet f*ck all about the tacho on a hilux and obviously it isnt working at all, i have no clue where the coil is as its being a diesel from my knowledge they dont have them, so can i just tap into a wire on a ln106r and feed it straight to the tacho or? any help would be appreciated Quote Link to comment
MikeRL411 Posted March 20, 2014 Report Share Posted March 20, 2014 I know nothing about the HiLux but just maybe that Diesel uses a mechanically driven tach? The early Datsun roadsters had an extended distributor shaft with a cable takeoff to the tach. That tach was essentially a speedometer driven from the distributor, not the driveshaft, so was calibrated in engine RPM. Ancient history but it worked, a tachometer that didn't depend on magnetic pickups and was dead accurate. Hope you get a more knowledgible response! Quote Link to comment
