LUIS COLCHETE Posted April 24, 2014 Author Report Share Posted April 24, 2014 Many thanks for your quicly replies Quote Link to comment
LUIS COLCHETE Posted April 26, 2014 Author Report Share Posted April 26, 2014 Hi ggzila Im just grinding the original exhaust mainfold to fit the new intake. But the new intake mainfold dont fit with motorhead, the studs of motorhead dont match with holes of intake mainfold To fit i need them i need to do one hole on the intake mainfold to fit the motorhead and make a hole on the gasket or buy a new one. Is this one choice. Is the correct one? I dont like open more holes ont the motorhead.... http://s1305.photobucket.com/user/luiscolchetelui/media/DSC_0945_zps93d0d2ad.jpg.html http://s1305.photobucket.com/user/luiscolchetelui/media/DSC_0947_zps89390552.jpg.html Many thanks, Luis Quote Link to comment
ggzilla Posted April 27, 2014 Report Share Posted April 27, 2014 Your cylinder head is for an A12 engine Your twin carb intake manifold is for an A14/A15 round port engine (or for a 1990-1994 A12). * You can buy a twin carburetor manifold for an A12 engine. Or * fit an A14 cylinder head to the A12 Or * drill a hole in the manifold to fit the A12 if there is room A12 manifold Quote Link to comment
LUIS COLCHETE Posted April 29, 2014 Author Report Share Posted April 29, 2014 HI Install a new intake I ve doubt, I have just talked about this.... but i think the easy way,is open two simply holes on the new intake mainfold and buy a new gasket... and it will resolve my problem. but my doubt is: one simple stud on original intake was enough to prevents leakages, and ok. Now two carbs and new intake are heavier than original but nothing to much, i still thinking on stud is enough? If exists intake mainfolds with only hole i think there is no problem What do you think? The other solution is remove the 2 studs on motorhead and open 4 new thread in it, but the motorhead looks like a cheess swiss I dont like this choice. The first solution is enough? Many thanks Luis Quote Link to comment
ggzilla Posted April 30, 2014 Report Share Posted April 30, 2014 The one-stud type was used for racing. Two bolts attach each intake flange at the bottom. So three fasteners total for intake ports at front and three for the rear intake ports. Quote Link to comment
LUIS COLCHETE Posted May 1, 2014 Author Report Share Posted May 1, 2014 Hi Do you know where i can find spare gaskets, diaphragm in case... http://s1305.photobucket.com/user/luiscolchetelui/media/_571_zps8c19fda3.jpg.html Quote Link to comment
ggzilla Posted May 1, 2014 Report Share Posted May 1, 2014 Use the IMG link You can purchase the gaskets from a carburetor shop. PHH air cleaner/filter gaskets are different from DCOE gaskets. Quote Link to comment
LUIS COLCHETE Posted May 2, 2014 Author Report Share Posted May 2, 2014 Hi! I ve consult the site Wolf Creek Racing and i see the the model Mikuni/Solex 40pHH Type T i thinks is equal of mine, but the vendor on ebay inform me the model is Type S5, i think he is wrong? According with them the throtlle Buterfly is stamped 165. Please confirm me Quote Link to comment
ggzilla Posted May 2, 2014 Report Share Posted May 2, 2014 Type T means originally fitted to Toyota. Could be model S5. Quote Link to comment
LUIS COLCHETE Posted May 2, 2014 Author Report Share Posted May 2, 2014 I see the picture... and the mention was Mikuni T How can i have 100% of certain of the model? Must contact Toyota with reference of 21100-88255 green stamp on carb.Because i want a spare of gaskets to keep it in reserve Thanks Quote Link to comment
ggzilla Posted May 2, 2014 Report Share Posted May 2, 2014 Just get mikuni PHH40 gaskets. I used Weber DCOE gaskets but had to cut extra holes in them. Quote Link to comment
LUIS COLCHETE Posted July 1, 2014 Author Report Share Posted July 1, 2014 Hi! I need help.... from you I can put A14 header on A12 enginee............ I will do these because i have one Harada intake Mainfold with four holes and my actual Head has only two holes and to solve the problem of header, i will buy a A14 head and respective exhaust mainfold to put on my A12 engine. I think it fits perfect. What do you think? I need your tecnical information The A14 cylinder has the thiner screw to lubrification? Many thanks, Luis Quote Link to comment
ggzilla Posted July 2, 2014 Report Share Posted July 2, 2014 All A-series engines have one thinner head bolt which allow oil to flow through the bolt passage. Yes, A12 exhaust manifold or header will bolt to A14 head. And vice-versa. A14 head and some A12 heads use a 4-bolt intake manifold flange. Some A12 (but not all) have a 2-bolt flange. A12/A14 4-bolt intake manifolds. Quote Link to comment
LUIS COLCHETE Posted July 2, 2014 Author Report Share Posted July 2, 2014 Hi! Many thanks I already bought from a Ratsun member a A14 Head and a header to mount my A12 Engine and fit the Harada Intake mainfold that i bought I read "the 1967-1973 heads provide oil to the rocker arm shifts in diffrnt locations than 1974 up so when fitting a newer head you may need to redrill the oil passage" I need compare my actual A12 Head to my newer Head A14. This is true? This newer head will increase some horspepower with my twin Mikuni Solex 40 phh. Maybe 15 or 20 Hp. Many thanks for all your knowldeges and help Luis Quote Link to comment
LUIS COLCHETE Posted July 16, 2014 Author Report Share Posted July 16, 2014 Hi! I saw this header 1200 gx model south africa i suppose RHD.at a reasonnable price This header will fit my LHD my Datsun 1200?. Or i have to cut it and weld to my A12 actual Header? http://olx-t.imgrap.com/ui/32/24/65/459041965_1x.jpg?x=1405353161 Many thanks on advance Luis Quote Link to comment
LUIS COLCHETE Posted July 17, 2014 Author Report Share Posted July 17, 2014 Please let me know if this Header from Datsun 1200 GX RHD fits my Datsun LHD... Many thanks, Luis Quote Link to comment
LUIS COLCHETE Posted October 7, 2014 Author Report Share Posted October 7, 2014 Hi! Vaccum advance on twin sidedraft carburateur is necessary? The vacum advance canister on a distributor is lilte more than decoration. it is correct? Quote Link to comment
banzai510(hainz) Posted October 7, 2014 Report Share Posted October 7, 2014 my 40mm Mikunis one of the carb has a port and has a hose to the vaccum adv. i DONT GET HOW IT WORKS AS IT HOOKS UP TO ONLY ONE POERT AND CYLINDER SO YOU CANT GET A SMOOTH VACUUM My 44 mikunis on my other car does not have this port. But has a SSS distributor with a faster advance. But nothing is hooked up to it. Hope this helps. if it runs with out it dont worry about it Quote Link to comment
LUIS COLCHETE Posted October 11, 2014 Author Report Share Posted October 11, 2014 Hi! Where i can find remote reservoir brake master cilinder for my Datsun 1200? Quote Link to comment
