LUIS COLCHETE Posted March 19, 2014 Report Share Posted March 19, 2014 Hello! I recently bough a twin Mikuni 40phh WITH 32MM venturis, mainjet 160 and airjet 210, now i now is a bit large for my A12 Datsun B110 engine.1200cc Its enough change the jets or i need to change the venturis? Many thanks on advance Luis Quote Link to comment
ggzilla Posted March 19, 2014 Report Share Posted March 19, 2014 Why change the jets? Is the air/fuel ratio incorrect? Put it on and drive it. I had 32mm on my A12 engine. It ran OK, excellent power. To make it run perfect, I suggest 29mm venturis. The jets should match the venturis, so if you tune the venturi size get new jets to match. Quote Link to comment
LUIS COLCHETE Posted March 19, 2014 Author Report Share Posted March 19, 2014 I will put it and run it without any changes... i WILL TELL Quote Link to comment
LUIS COLCHETE Posted April 15, 2014 Author Report Share Posted April 15, 2014 I m just begining the carb Project If i have any doubts i will talk with this comunity. http://s1305.photobucket.com/user/luiscolchetelui/media/DSC_0935_zps9645c43e.jpg.html Thanks at all of you Luis Quote Link to comment
LUIS COLCHETE Posted April 16, 2014 Author Report Share Posted April 16, 2014 The vacum system One carb has to pipes, another one has only one. These are to link to the distribuitor vacum, im correct? Please inform how i link them I will remove the srew on intake and i wil link to my brake servo On the top of the carbs exist a system with a pulling spring, i think they are a choke system and i will link them with my car cable choke Im correct? Many thanks, Luis http://s1305.photobucket.com/user/luiscolchetelui/media/DSC_0936_zpse3e8b469.jpg.html http://s1305.photobucket.com/user/luiscolchetelui/media/DSC_0937_zpsb8255a2a.jpg.html http://s1305.photobucket.com/user/luiscolchetelui/media/DSC_0938_zpsfdc1def8.jpg.html http://s1305.photobucket.com/user/luiscolchetelui/media/DSC_0939_zpsda836f75.jpg.html Quote Link to comment
ggzilla Posted April 16, 2014 Report Share Posted April 16, 2014 Use the photobucket "Direct" link. These are the fuel inlets. The other carburetor will have a single inlet. Fuel hose Quote Link to comment
ggzilla Posted April 16, 2014 Report Share Posted April 16, 2014 Starter choke: Yellow circles. Connect choke cable to these. Quote Link to comment
LUIS COLCHETE Posted April 17, 2014 Author Report Share Posted April 17, 2014 Hi! The pipes im referring is the vacum to link to distribuitor, the small yellow one not the fuels. One carb has two another has only one. I think i need only one and i must plug the others to avoid leaks. Im tinking wright? Many thanks Luis Quote Link to comment
ggzilla Posted April 17, 2014 Report Share Posted April 17, 2014 The yellow arrows point to the mixture adjustment screws Quote Link to comment
ggzilla Posted April 17, 2014 Report Share Posted April 17, 2014 My mikunis did not have vacuum ports. But in general you can plug them and leave the distributor unconnected. Quote Link to comment
metalmonkey47 Posted April 17, 2014 Report Share Posted April 17, 2014 If you want to run a vacuum advance, connect one to the distributor, and plug the extra's. Or you could plug them all, but it's not a bad thing to have vacuum advance. Quote Link to comment
LUIS COLCHETE Posted April 17, 2014 Author Report Share Posted April 17, 2014 hI! Thanks all of you... Anybody inform me about the mixture screws and idle ones. Can i change the choke springs? Because this carbs were working in another enginne. The inlet was in opposite way. and i need to push the cable not pull. Many thanks, Luis Quote Link to comment
ggzilla Posted April 17, 2014 Report Share Posted April 17, 2014 Anybody inform me about the mixture screws and idle ones.The yellow arrows point to the mixture adjustment screws Green arrows point to idle speed screws Adjust them exactly like a Hitachi carburetor Quote Link to comment
LUIS COLCHETE Posted April 17, 2014 Author Report Share Posted April 17, 2014 Thank you for your reply Can i change the position of idles? I need to push the choke cable not pull. Luis Quote Link to comment
ggzilla Posted April 17, 2014 Report Share Posted April 17, 2014 Choke cables and the Starter choke are made to pull, not push. Here is the factory Datsun twin choke cable, it is quite long They are not rare, as Datsun Roadster also used them. BProjects sell them New Datsun Parts sell them I left mine disconnected. They are only needed when cold. I opened the bonnet and turned them 1/4" by hand. Quote Link to comment
mrbigtanker Posted April 18, 2014 Report Share Posted April 18, 2014 Lisboa Portugal. Quote Link to comment
ggzilla Posted April 18, 2014 Report Share Posted April 18, 2014 Both stores are outside USA but they ship internationally. I've bought parts from both of them. Quote Link to comment
LUIS COLCHETE Posted April 18, 2014 Author Report Share Posted April 18, 2014 Where Lisboa? Do you have a fuel regulator? and you a Stock fuel pump? I think you told me that the stock one its enough to. Do you have pictures about the return pipe. Many thanks Luis Quote Link to comment
ggzilla Posted April 18, 2014 Report Share Posted April 18, 2014 Return pipe is not needed. Just cap the line at the firewall. Keep the carbon canister connected to ventilate the fuel tank. Quote Link to comment
LUIS COLCHETE Posted April 18, 2014 Author Report Share Posted April 18, 2014 Sorry can you explain me better:"Keep the carbon canister connected to ventilate the fuel tank". The Original fuel pump its enough? becuase i learn Mikuni requires 3.5psi to carbs any time running. it is very important to use fuel regurator? Or i can run the carbs with my stock fuel pump and nothing more Luis Quote Link to comment
LUIS COLCHETE Posted April 18, 2014 Author Report Share Posted April 18, 2014 Please advice or tell me what the steps you do, to mount your mikunis Many thanks Luis Quote Link to comment
ggzilla Posted April 18, 2014 Report Share Posted April 18, 2014 I would use the stock fuel pump. If you are running a high-pressure fuel pump, use a regulator. Mikunis do not need a return line. The fuel tank must be vented. Do not block the vent line. Quote Link to comment
LUIS COLCHETE Posted April 18, 2014 Author Report Share Posted April 18, 2014 The fuel tank must be vented. Do not block the vent My fuel tank is original, it has normal breathing system. and a normal gas cap. The fuel tank in original it is vented? It is correct what im sayng? What do you think?, i dont need nothing? neither buy high pressure pump neither regulator?. Just put the new intake carbs on a standard fuel system and tune correct the carbs. Many thanks for your help Luis Quote Link to comment
