Bonvo's pacifier 77 620kc
bonvo
  • Replies 127
finished relocating the seat today and bled the brakes and clutch i think someone put the wrong throw out collar in this thing at one point or another as the clutch has alot of free play anyway on with the pics
I was stoked that i didnt have to relocate the seatbelt stuff
and this shows how far back i moved the seat
still not the most comfortable thing to drive but alot better then before
next on the list is to completly take the front end apart repack wheel bearings lube up brake adjuster and properly adjust brakes then rig up a throttle stop and throttle return spring
still have the sentra its my daily driver lol i cant mess with the sentra without voiding the warrenty and i love it how it is so ive just been driving it this so far has cost me next to nothing to mess with and i made a profit off the subaru i may keep this truck i may not if i sell it the money goes into the sentra
figured out why it wont idle higher then 450 rpm when cold the carb is missing a few parts such as the fast idle cam linkage
now do i make a rod to connect them or just pull the weber off the 610 and put my 40 on the 610
  • 1 month later...
  • 3 weeks later...
got a mirror on it adjusted the brakes repacked and adjusted the front wheel bearings fixed the seatbelts all to get it ready to drive it 400 miles tomorrow to my sisters wedding
well i made it but it was a road kill kind of road trip the points and condencer werent happy so i had to stop and adjust them then it was running at 210 from redding to vacaville (3 hours) so new points and condencer are on the way and im gonna find out what thermostat is in this thing and add some water wetter to it so i can get home on tuesday
  • 3 weeks later...
well now that was one HELL of a trip after the wedding i went to a friends place to use his air compressor so i didnt break the thermostat housing bolts on the way there i loose all clutch i limp it to his place bleed the clutch with no  luck so i replaced the master and slave new thermostat and points set the dwell and check the timing.... and it was running at 0 degrees advance so i said fuck it and did a full tune new plugs and all running ALOT better then it was before and i fixed my low clutch pedal when i replaced the clutch hydraulics keep in mind all of this in front of a friends house 400 miles from home with a fucked up let in 100 degree heat yeah i was not happy due to it having so many issues i waited till zerow was heading up to canby so i could follow him in case something went wrong
