Datsun 521 "Susie Q"
  • Replies 103
  • 3 weeks later...
Alright I've been slacking..time to do some updating.
Got the engine bay prepped. BEFORE
AFTER
New turbo lines installed and s14 waterneck
E7284310-25D0-4394-B5E9-D030B87951B5_1.j
Custom ratsun motor mounts. Yes they're hockey pucks.
9C21F97A-55BA-471C-B3DC-5C2136332396_1.j
Got the engine wired up (wire tuck)
Transmission mount made. I cut and reused the stock l16 mount and welded it to a flat piece and drilled holes and used the preexisting crossmember holes.
Relocated and put a battery under the emissions cover in the bed
Also installed and wired up the fuel pump. Waiting on my radiator and alternator to arrive. The steering bar should be done this week. And if I find a compressor and it fits I'll be able to keep my ac!
Ugh yes. I plan on Fixin it. My buddy has just been busy with his welder lately. Eventually I want to fill all the unused holes. My buddy has some ties at a technical institute so he might be able to get the truck in to get body work and paint done as a "project" free of charge to me. I'd just have to pay for paint so I'm waitin to hear back about that before I do anything.
  • 4 months later...
Well I've been slacking on this project for the last couple of months but I finally got a drive shaft made and bought an AEM stand alone for the sr20. Going to get it tuned and get the greddy boost controller and turbo timer hooked up. Should be able to drive it pretty soon. Still have to do brake upgrades tho. Debating on going with a different rear end, I'm sure the stock 521 wont last too long.
I heard the 521 diff can only take maximum around 250 hp, someone correct me if im wrong
yea im hoping to have just under 300hp. I also have some adjustable control arms that i took off of my jeep wrangler that im debating on fabbing up a 4 link/ladder bar sytem to minimize wheel hop. I definitely dont plan on the diff lasting forever, but i also dont plan on launching it from a dig. Im sure ill have my fair share of burnouts tho.. i mean hp, boost, 521... who could resist :thumbup:
The H190 is a very strong differential, honestly how many people you heard of that have taken one out from anything other than just wearing them out from heavy use like what I do.
EricJB drag races his, and I don't recall him busting one yet, and he is using old pumpkins out of 320s with alloy housings which are what the 521 has, you can change over to the steel housings used in the 720.
Also the truck H190 has huge axles except of the 320, but unless you are using a 320 rearend so you can mount wider wheels/tires, I would not worry about the rearend right now until you do have an issue.
Here is Eric's thread.
http://community.ratsun.net/topic/39329-project-drag-521/
  • 1 month later...
