Datsun 521 "Susie Q"
  • Replies 103
Well got my rims and tires on. Have had a vibe around 55 and up, I think it might be the slip yoke on the driveshaft so I might be going to a one piece shaft unless anyone has any input? I put the truck to stock ride height, still had vibe. I lowered it down and fixed the pinion angle, still has a vibe. The carrier bearing seems solid and doesn't have any play or movement so idk what else it could be. Any input would be appreciated. Anyways here's some pics!
are those wheels hub centric or lug centric,also for shits and giggles does the hub hole fit over the hub of the drum so what ia m trying to say is do they fit flush against the drums and did you get the tires balanced.
Are they used wheels, are they bent did you watch the guy balance them if your king pins are still solid and you have no play in the carrier bearing and it did not do it before then its got to be those cheap ass wheels.
  • 2 months later...
