red13 Posted February 6, 2015 Author Report Share Posted February 6, 2015 What did you use on the frame? I used a wirebrush grinding wheel to clean the rust. Then 91% alcohol to wipe down and insure it was clean then 2 coats of primer for now. Ill get some undercoat stuff when I am done. 2 Quote Link to comment
Hrvat9 Posted February 26, 2015 Report Share Posted February 26, 2015 I used a wirebrush grinding wheel to clean the rust. Then 91% alcohol to wipe down and insure it was clean then 2 coats of primer for now. Ill get some undercoat stuff when I am done. Rattled can primer ? Kinda stuck on what to use on bare metal ...did some research and they say "epoxy primer" seals the metal, but it can only get mixed up at a paint store, no rattle can epoxy primer 1 Quote Link to comment
ownTer Posted February 26, 2015 Report Share Posted February 26, 2015 If there is any boating places around. Stop in and ask if they have any 302. Its a 2 part epoxy paint we use on ships and what not. Good stuff for sure. 2 Quote Link to comment
Draker Posted February 26, 2015 Report Share Posted February 26, 2015 Rattled can primer ? Kinda stuck on what to use on bare metal ...did some research and they say "epoxy primer" seals the metal, but it can only get mixed up at a paint store, no rattle can epoxy primer Actually, if you go to a paint store they can sell you epoxy primer in a spray can that has an activator that your break. then you shake it up and spray it like normal. So yes, you can get it in a spray can. It's probably a one time use thing though. 1 Quote Link to comment
Hrvat9 Posted February 28, 2015 Report Share Posted February 28, 2015 Sweet! Thanks draker and ownTer , on to the next paint/ boating store ! 1 Quote Link to comment
krayziemike001 Posted February 28, 2015 Report Share Posted February 28, 2015 Sweet! Thanks draker and ownTer , on to the next paint/ boating store !You don't really need epoxy primer.Etch primer and then your topcoat is fine. And I believe you can get chassis paints that are designed to be sprayed over bare steel. (I'm a panelbeater/painter) 1 Quote Link to comment
SadieD Posted May 4, 2015 Report Share Posted May 4, 2015 Looks great : ) ....and you have a tach, I'm jealous. 2 Quote Link to comment
red13 Posted July 9, 2015 Author Report Share Posted July 9, 2015 started a fb page with links and tips if anyones interested https://www.facebook.com/pages/Hackers-Hack-Up-1973-Datsun-620-Rebuild/1854433418114441 1 Quote Link to comment
SPIDERSHACKOV Posted July 10, 2015 Report Share Posted July 10, 2015 Nice build. Seems to be coming along. What product did you use on the dash and center console? 1 Quote Link to comment
red13 Posted July 10, 2015 Author Report Share Posted July 10, 2015 Nice build. Seems to be coming along. What product did you use on the dash and center console? Rhinolining 1 Quote Link to comment
red13 Posted August 9, 2015 Author Report Share Posted August 9, 2015 Past couple of days Frame doneish Cab underside mostly done Engine bay clean and painted wiring is next 2 Quote Link to comment
Elkie Posted August 10, 2015 Report Share Posted August 10, 2015 What'd you use to painting? Quote Link to comment
red13 Posted August 10, 2015 Author Report Share Posted August 10, 2015 What'd you use to painting? For the frame and cab i used etched primer, automotive primer, rubberized under coating in a spray can. For the engine bay, etched primer, automotive primer, textured mettalic 1 Quote Link to comment
red13 Posted November 20, 2015 Author Report Share Posted November 20, 2015 Forgot to post, but started working the new to me bed Scored some NOS emblems off ebay 2 Quote Link to comment
sebpv Posted November 20, 2015 Report Share Posted November 20, 2015 you too? My dad should be picking mine up sooner or later... I recall seeing only one pair for sale, I thought I was special... Quote Link to comment
red13 Posted November 20, 2015 Author Report Share Posted November 20, 2015 you too? My dad should be picking mine up sooner or later... I recall seeing only one pair for sale, I thought I was special... they were tucked away in ebay, I was the only watcher and bidder. Quote Link to comment
sebpv Posted November 20, 2015 Report Share Posted November 20, 2015 Did you have to mention between 1500 or 1600 emblems? Quote Link to comment
red13 Posted November 20, 2015 Author Report Share Posted November 20, 2015 Did you have to mention between 1500 or 1600 emblems? no just randomly searched Quote Link to comment
sebpv Posted November 20, 2015 Report Share Posted November 20, 2015 different one for sure then Quote Link to comment
DarkStar620 Posted January 29, 2016 Report Share Posted January 29, 2016 What did you add? Not to sound too noob haha? Also are you going to be adding disk brakes now? Quote Link to comment
