320 voltage regulator
tonalteco
  • Replies 13
I forgot to mention my 320 has a 1600 engine out of a 521. Seems like the regulator that already had installed was one which has about 6 wires caming out of it (i heard its the one used on the 510's or other datsuns). I wanted to use the original regulator but like it was said above, it wont use the stock generator.
I will post a pic and maybe it will make more sense.
Thanks in advance
You can get an external VR easily at Autozone or anywhere for like $30, but be warned most are crap and will fail.  I went through 3 of them I think.  Outsourcing electronics manufacturing to China has not gone well.
I eventually gave up and just bought a different alternator with internal reg.
  • 2 months later...
That eBay one don't work for the 320. Its for an alternator.
But it works for the 521 alternator.
Maybe so, but it is a lead to a seller who may have the correct part.
It also leads one to the eBay category where the part may be found.
You gotta start somewhere.
