Ranman72 Posted May 17, 2014 Author Report Share Posted May 17, 2014 more new parts I took the car for a test run today after fixing the wire problem and ended up towing it back home with my truck somehow along with the broken wire problem the fuel line was plugged up it was sucking air bubbles into the fuel filter I thought the fuel filter might be cracked so I replaced it with another new one I tried to blow back through the fuel line to the tank and it had alot of resistance so I got the air hose out I heard a pop in the fuel tank and then bubbles so far so good seems to be ok I will half to drain the tank to see what might have plugged it Quote Link to comment
ggzilla Posted May 17, 2014 Report Share Posted May 17, 2014 That's a 510 room lamp. The 1200 version has a milky lens. The 510 crystal lens looks better and works better too. 1 Quote Link to comment
Ranman72 Posted May 19, 2014 Author Report Share Posted May 19, 2014 so today i dug into the fuel tank drained it and pulled the sender unit. The sender was not working so I sanded the contacts and bent the spring arm to have more pressure on the resister to my surprise I found alot of debris in the tank I filled and drained the tank about 8 times till all the debris came out I guess when I filled the tank halfway and drained it alot of the debris remained attached and loosened over time for the good stuff this was the debris in the bucket that made it through the mesh filter it is fine grime and now the fuel gauge works 4 Quote Link to comment
Ranman72 Posted May 24, 2014 Author Report Share Posted May 24, 2014 taking it on another test run tonight about a 50 mile test run and no problems I think all is well now hopefully these are correct tie rods for the 1200 we will see tomorrow 1 Quote Link to comment
Ranman72 Posted May 25, 2014 Author Report Share Posted May 25, 2014 well today was install day and everything went great till the last tie rod end it was normal thread instead of reverse thread for the drivers side outer put the other three in and an old but better than the one on the car drivers outer so the outers were made in Japan and the inners made in south korea inners also use nylon nut and no cotter pin outers are cotter pin type old rubber boot but better then the one that was on the car this will be new next weekend installed some sound deadening and carpet today 1 Quote Link to comment
Ranman72 Posted May 26, 2014 Author Report Share Posted May 26, 2014 today we went on the bluebird cafe fun run total miles were 383 door to door this run was a blast we went on some very curvy roads and some were pretty bumpy too the run was a blast and an excellent shakedown on the 1200 we had one mechanical problem, the passenger strut gland nut came loose ( the nut that holds the strut insert in the case ) we stopped and jacked the car up found the nut to be loose , borrowed from another ratsuner a large pair of channel locks to tighten it I believe it was eastbay521 who supplied them we checked the drivers side while we were at it and it was ok [/uR L] Quote Link to comment
CGS1948 Posted May 26, 2014 Report Share Posted May 26, 2014 today we went on the bluebird cafe fun run total miles were 383 door to door this run was a blast we went on some very curvy roads and some were pretty bumpy too the run was a blast and an excellent shakedown on the 1200 we had one mechanical problem, the passenger strut gland nut came loose ( the nut that holds the strut insert in the case ) we stopped and jacked the car up found the nut to be loose , borrowed from another ratsuner a large pair of channel locks to tighten it I believe it was eastbay521 who supplied them we checked the drivers side while we were at it and it was ok [/uR L] [url=http://s1132.photobucket.com/user/ranman68/media/IMG_20140525_170452_825_zpslnllt4tb.jpg.html] The 1200 looks great Randy, Nice to see another one alive, well, and on the road again!!! The patina looks perfect, almost enough to leave it that way. B) Quote Link to comment
Ranman72 Posted May 27, 2014 Author Report Share Posted May 27, 2014 well we did some more work today checked and tightened both the strut gland nuts and found other loose nuts on the front end the drivers control arm bolt was loose NEVER trust anything that was put together by someone you dont know this crazy guy named Atom suggested we polish the patina and I am happy to say it was a great idea loose control arm bolt added these to the just in case tool box be careful with these if they slip this will happen next we tried this out before the fender is done the door is not we used all three of these products after polishing 1 Quote Link to comment
datsunfreak Posted May 29, 2014 Report Share Posted May 29, 2014 FWIW, all four of mine are like this. inners also use nylon nut and no cotter pin Quote Link to comment
ggzilla Posted May 29, 2014 Report Share Posted May 29, 2014 If you want them to match, you can remove the nylock nut and put a castle nut & cotter pin, but the nylock works well enough. Quote Link to comment
Ranman72 Posted May 30, 2014 Author Report Share Posted May 30, 2014 they dont need to match it was just interesting that manufactured in different places but sold under the same label had different styles Quote Link to comment
Ranman72 Posted June 1, 2014 Author Report Share Posted June 1, 2014 installed the last tie rod end today YAY it was correct also beat on the rim a bit it had some tweaks that would rub the tie rod end ALL FIXED Quote Link to comment
Ranman72 Posted June 7, 2014 Author Report Share Posted June 7, 2014 went to Busta Nuts shop today had some issues today on the way back from the alignment shop approx 220 mile round trip and the fuel line got plugged again time to drain and filter the tank again it looked very good last time but there must still be some junk in there [/url] Quote Link to comment
Ranman72 Posted June 8, 2014 Author Report Share Posted June 8, 2014 so we had some fuel problems on the way back from the alignment shop it seems everything on this car has to be done at least twice so I drained the fuel tank again and this came out right away so I filled and repeat about 15 times I quit taking pics after about 5 also found one of the small rattles the car had in the rear an old exhaust hanger piece was hitting the side of the shock I will cut that off tomorrow Quote Link to comment
ggzilla Posted June 8, 2014 Report Share Posted June 8, 2014 Yes, it will be a while until that clears out. Had both problems with my 1200. Quote Link to comment
Ranman72 Posted June 9, 2014 Author Report Share Posted June 9, 2014 gave it one last wax before Canby I love this stuff it came out really good also ground of the old exhaust bracket hanger that was rubbing the shock sometimes lighting was terrible though Quote Link to comment
Ranman72 Posted June 17, 2014 Author Report Share Posted June 17, 2014 well canby trip was un eventful no problems at all 30 miles to the gallon and she hit 98 MPH catching up to the bay area guys on the way home and still had room to go no awards this year the Chinook camper took first the NISSAN PATROL TOOK SECOND AND THE BEST CAR IN THE OTHER CATEGORY TOOK THIRD IT WAS A REALLY NICE BLACK AND BLUE 610 1 Quote Link to comment
ggzilla Posted June 17, 2014 Report Share Posted June 17, 2014 98 MPH on a 1200 speedometer is about 85 actual MPH. Quote Link to comment
ggzilla Posted June 17, 2014 Report Share Posted June 17, 2014 the Chinook camper took first Was it this one? today at kam iii beach Quote Link to comment
Ranman72 Posted June 17, 2014 Author Report Share Posted June 17, 2014 98 MPH on a 1200 speedometer is about 85 actual MPH. it was 98 on gps Quote Link to comment
Ranman72 Posted June 17, 2014 Author Report Share Posted June 17, 2014 nope it was this one 1st place in other second place in other datsuns blue nissan patrol third place Quote Link to comment
