MrBigTanker got a wagon now.Oh boy.
mrbigtanker
  • Replies 1.5k
adventures with trannys  :devil:  :devil:  :devil:  :devil:
transmissions that is  :thumbup:  :thumbup:  :thumbup:  :thumbup:
You can use the P12 CAS or the Mazworx sensor and a solenoid relocation kit to work on the RWD bottom end. This has been done many times in several RWD applications. You also need to use the VVL metal head gasket with the VVL oil pump with a modified pickup.
They're old school theft prevention. They're snap off screws. The heads break off once they're tightened from the factory. When I replaced my ignition, I used a dremel to cut a slot on the bald rounded nub that was sticking out and used a flat head screwdriver to back them out.
Yea i found that out but its off and I got a new NOS set I bought for the wagon.
