RTB Posted February 10, 2014 Report Share Posted February 10, 2014 I got a terrific deal on 15x6 panasports but I'm having trouble choosing a tire size. It seems to fall into a category of being too narrow for nowadays performance tires. I don't really want to spend more than 400 dollars for the set and want them to be close to flush with the wheel lip. Any suggestions? Quote Link to comment
datsunfreak Posted February 10, 2014 Report Share Posted February 10, 2014 I got a terrific deal on 15x6 panasports but I'm having trouble choosing a tire size. It seems to fall into a category of being too narrow for nowadays performance tires. I don't really want to spend more than 400 dollars for the set and want them to be close to flush with the wheel lip. Any suggestions? Offset? Assuming this is for the 510? Front suspension? I would suggest a 195/50-15, unless something in your answers to those questions throws me for a loop. B) Quote Link to comment
RTB Posted February 10, 2014 Author Report Share Posted February 10, 2014 Offset? Assuming this is for the 510? Front suspension? I would suggest a 195/50-15, unless something in your answers to those questions throws me for a loop. B) Close to zero offset. for a 510. Datsun Comp suspension (standard 510 struts with japanese insert and coil). Quote Link to comment
datsunfreak Posted February 10, 2014 Report Share Posted February 10, 2014 Close to zero offset. for a 510. Datsun Comp suspension (standard 510 struts with japanese insert and coil). Chances are good the fronts will poke out regardless of tire size. I'd still go with a 195/50-15. Good selection of tires, good fit for a 6" wheel, and a good diameter for a 510. Quote Link to comment
RTB Posted February 10, 2014 Author Report Share Posted February 10, 2014 Chances are good the fronts will poke out regardless of tire size. I'd still go with a 195/50-15. Good selection of tires, good fit for a 6" wheel, and a good diameter for a 510. I know theres a big difference between tire manufactures on width. Quote Link to comment
KlassicMotion Posted February 10, 2014 Report Share Posted February 10, 2014 195/50/15; for all intents and purposes, is the same diameter as the common 185/60/14. I'm running the 185/60/14 and it does seem to be about perfect. Quote Link to comment
datsunfreak Posted February 10, 2014 Report Share Posted February 10, 2014 I know theres a big difference between tire manufactures on width. I wouldn't say "big", but if that's you're concern then get some of these... http://www.tirerack.com/tires/tires.jsp?tireMake=Kumho&tireModel=Ecsta+AST&partnum=95HR5EAST&vehicleSearch=false&fromCompare1=yes Good size, good in the rain, last well, and don't cost much. :thumbup: Quote Link to comment
RTB Posted February 10, 2014 Author Report Share Posted February 10, 2014 are 205/50r15 too wide? Quote Link to comment
ggzilla Posted February 10, 2014 Report Share Posted February 10, 2014 Yes 205-width tires. Manufacturers suggest minimum rim width of 5.5" max 7". Quote Link to comment
datsunfreak Posted February 10, 2014 Report Share Posted February 10, 2014 are 205/50r15 too wide? A little too wide, a little too tall, and even more fender poke, so... :rofl: Quote Link to comment
datsunfreak Posted February 10, 2014 Report Share Posted February 10, 2014 want them to be close to flush with the wheel lip. This should rule out 205s pretty quickly. ;) Quote Link to comment
KlassicMotion Posted February 10, 2014 Report Share Posted February 10, 2014 datsunfreak is correct, with the stock 510 struts, and Zero offset wheels, the wheels themselves will stick out past your fenders, regardless of the tires. My setup is the 280zx struts, which moves the hub surface inward 1/2". Plus my wheels are 6" wide with +10mm offset. The side wall bulge is tucked about 1/2" inside the wheel arch lip. Quote Link to comment
RTB Posted February 10, 2014 Author Report Share Posted February 10, 2014 So what you're saying is I should swap struts. Quote Link to comment
KlassicMotion Posted February 10, 2014 Report Share Posted February 10, 2014 Oh, most definitely!! :D Quote Link to comment
datsunfreak Posted February 10, 2014 Report Share Posted February 10, 2014 So what you're saying is I should swap struts. If you're in love with these wheels, it'll be the only "easy" way to get them inside the fenders. :thumbup: There are other benefits as well, bigger brakes, better parts availability, better scrub radius, etc. Quote Link to comment
banzai510(hainz) Posted February 11, 2014 Report Share Posted February 11, 2014 I have Nexen 195 45 15s Quote Link to comment
KlassicMotion Posted February 11, 2014 Report Share Posted February 11, 2014 I have Nexen 195 45 15s Got a pic? Quote Link to comment
banzai510(hainz) Posted February 11, 2014 Report Share Posted February 11, 2014 yes i do have but dont know how to post on Rastun since they changed the set up and I aint going to learn. but I have a 7in rim. Quote Link to comment
datsunfreak Posted February 12, 2014 Report Share Posted February 12, 2014 I have Nexen 195 45 15s This post is useless without pics. B) Here's a 195/45-15 on a 15x7 +0. It's actually too small a diameter for a 510, but if you're going fairly low it will let you go lower... :thumbup: 1 Quote Link to comment
datrod Posted February 12, 2014 Report Share Posted February 12, 2014 195-50-15 on a Nissan stock 6" wheel Quote Link to comment
datrod Posted February 13, 2014 Report Share Posted February 13, 2014 Not as cool as a real 510. But you get the idea. 1 Quote Link to comment
ggzilla Posted February 13, 2014 Report Share Posted February 13, 2014 Are those 240SX rims? They are +40 offset I think. Quote Link to comment
MARS 510 Posted February 14, 2014 Report Share Posted February 14, 2014 I think those are from the mid 80's 200sx. But I don't remember them having center caps.. Hey DATROD what kind of center caps are those from? 1 Quote Link to comment
510T Posted February 14, 2014 Report Share Posted February 14, 2014 S12 200sx wheels here 15x6 +38, 195/45 front 205/45 rear: 195/45 in my opinion is too small for a 510 unless you are totally slammed. On the 200sx they came from there were mini center caps and outer trim rings if I remember correctly... Quote Link to comment
