Janksun Posted February 6, 2014 Report Share Posted February 6, 2014 Which lug nuts match this wheel? A shank lug? Quote Link to comment
TENDRIL Posted February 6, 2014 Report Share Posted February 6, 2014 looks like it Quote Link to comment
datsunaholic Posted February 6, 2014 Report Share Posted February 6, 2014 Just remember there are multiple size shank lugs. Got a nasty surprise when I thought I had enough (picked up every one I could find in the dirt at the PnP after someone took all the mag wheels off several cars but left the nuts) but they were different shank diameters. If the shank is too small, the wheel won't center. Quote Link to comment
yenpit Posted February 10, 2014 Report Share Posted February 10, 2014 Go to Gorilla, McGard etc etc, check their detailed charts for their lug nuts. Like datsunaholic said, LOTS of different lug nuts! As long as the holes go straight thru WITHOUT an obvious taper at the wheel face, you will want a straight shank lug nut. Measure the ID of the lug nut hole in your wheel, AND measure the depth of that hole to get the correct lug nut SHANK. Hope that helps! Quote Link to comment
