Dirttrack510 Posted February 11, 2014 Report Share Posted February 11, 2014 Those are nice. I like em' :) 1 Quote Link to comment
zat Posted February 11, 2014 Author Report Share Posted February 11, 2014 Those are nice. I like em' :) for the price, very worth it! NOS look without NOS price tag. Quote Link to comment
Dirttrack510 Posted February 11, 2014 Report Share Posted February 11, 2014 Wishlist 1. Adjustable lower control arm and TC rod 2. Rear camber and toe adjuster How hard was this to install, I'm thinking about buying this set up. Because... Moar lower :) 1 Quote Link to comment
KlassicMotion Posted February 11, 2014 Report Share Posted February 11, 2014 How hard was this to install, I'm thinking about buying this set up. Because... Moar lower :) http://www3.telus.net/byron510/meston_motorsports_003.htm FutoFab sells Byron's rear camber/toe brackets. These brackets only replace the inner trailing arm brackets, so when adjusting camber the outer bushing needs to be compliant to shift "off axis" when you move the inner pivot point for camber adjustment. We recommend using either the stock rubber bushings or monoball bushing replacements to keep the suspension from binding. FutoFab sells DPR monoball replacement bushings for the rear trailing arms (not listed on our site, please email me for info/purchase). This kit will replace all 4 trailing arm bushings, These, while snug fitting are not designed to be a press fit and will need to be tack welded in place once installed. The kit using the stock 510 pivot bolts is $295/set + S&H. ($6 US). We have these in stock. 1 Quote Link to comment
zat Posted February 12, 2014 Author Report Share Posted February 12, 2014 FutoFab sells Byron's rear camber/toe brackets. These brackets only replace the inner trailing arm brackets, so when adjusting camber the outer bushing needs to be compliant to shift "off axis" when you move the inner pivot point for camber adjustment. We recommend using either the stock rubber bushings or monoball bushing replacements to keep the suspension from binding. FutoFab sells DPR monoball replacement bushings for the rear trailing arms (not listed on our site, please email me for info/purchase). This kit will replace all 4 trailing arm bushings, These, while snug fitting are not designed to be a press fit and will need to be tack welded in place once installed. The kit using the stock 510 pivot bolts is $295/set + S&H. ($6 US). We have these in stock. wow these look real good! time to update my wishlist. Quote Link to comment
510T Posted February 12, 2014 Report Share Posted February 12, 2014 i wonder.. if one could find this trim... could one install on a usdm 510? Yes ;) oics in my "build thread" VVV Quote Link to comment
510T Posted February 12, 2014 Report Share Posted February 12, 2014 Zat please take some moar oics for us this car is so sweet! 1 Quote Link to comment
zat Posted February 13, 2014 Author Report Share Posted February 13, 2014 currently the car is prepared for compulsory inspection needed to change title. and m changing the license plate too! something more 510. 1 Quote Link to comment
zat Posted February 13, 2014 Author Report Share Posted February 13, 2014 Zat please take some moar oics for us this car is so sweet! thanx man. will do. Quote Link to comment
zat Posted February 28, 2014 Author Report Share Posted February 28, 2014 got this yesterday. free gift from a friend. it sat proudly on his vespa seat! gonna come in handy when redoing the upholstery. sample pix courtesy of google 1 Quote Link to comment
zat Posted March 3, 2014 Author Report Share Posted March 3, 2014 PO of my car decided he would do everyone a favour by swapping the original dashboard. He grafted in the whole dash of 1st gen honda accord(that was the trend back then). pfffffttttttt! For the sake of everyone's eyes i decided not to share the blasphemous pix here. That being said, i had to search high and low for a complete, decent condition dash(which is quite scarce here). so here goes: glovebox door hinge is busted radio delete with coin tray(i think) gauges looks good any suggestions on how to restore the plastic parts? do i need to paint them? 2 Quote Link to comment
KlassicMotion Posted March 3, 2014 Report Share Posted March 3, 2014 Personally I like to clean my plastic with some Meguiars Quik Interior Detailer and a "tooth brush". Then I wipe Mother's Protectant on it. Try it in a small un-noticeable spot before doing the whole thing, just to make sure you like the outcome. If that doesn't get you the look your going for, and you decide to paint it, you will have to clean the spot with some wax and grease remover like Deltron DX330 or equivalent before you paint it. I'm not sure if this is the correct color for you, but SEM makes some great Plasitc parts paint. I've used their "Honda black" bumper coater on some cars, and it was a perfect match to the 80's factory black paint, and durable. I would pick up some of this paint below and see if it's the color your going for... There might be some other options, I just grabbed this example from a quick search. http://www.autobodytoolmart.com/sem-flex-black-bumper-coater-39103-p-15329.aspx?gclid=CJa78vj99bwCFdBqfgodV0MAGg 1 Quote Link to comment
zat Posted March 3, 2014 Author Report Share Posted March 3, 2014 Personally I like to clean my plastic with some Meguiars Quik Interior Detailer and a "tooth brush". Then I wipe Mother's Protectant on it. Try it in a small un-noticeable spot before doing the whole thing, just to make sure you like the outcome. If that doesn't get you the look your going for, and you decide to paint it, you will have to clean the spot with some wax and grease remover like Deltron DX330 or equivalent before you paint it. I'm not sure if this is the correct color for you, but SEM makes some great Plasitc parts paint. I've used their "Honda black" bumper coater on some cars, and it was a perfect match to the 80's factory black paint, and durable. I would pick up some of this paint below and see if it's the color your going for... There might be some other options, I just grabbed this example from a quick search. http://www.autobodytoolmart.com/sem-flex-black-bumper-coater-39103-p-15329.aspx?gclid=CJa78vj99bwCFdBqfgodV0MAGg thanx for the info mate! will surely try them. Quote Link to comment
zat Posted March 4, 2014 Author Report Share Posted March 4, 2014 here's the state of my dash pad. sent it for re-upholstery today. will pick it up in a couple of days. Quote Link to comment
Busta Nut Posted March 4, 2014 Report Share Posted March 4, 2014 Man.....great work!! That's a sweet dime you got.......keep up the good work... Looks great!! 1 Quote Link to comment
zat Posted March 5, 2014 Author Report Share Posted March 5, 2014 Man.....great work!! That's a sweet dime you got.......keep up the good work... Looks great!! Thanx man. 1 Quote Link to comment
zat Posted March 10, 2014 Author Report Share Posted March 10, 2014 after 2 days and $30, here's how it looks: compared to: its hard to find a proper dash restorer here. so i had to opt for rewrap. good enough for me, for $30. 1 Quote Link to comment
Busta Nut Posted March 10, 2014 Report Share Posted March 10, 2014 Looks great!! Good work :thumbup: 1 Quote Link to comment
KlassicMotion Posted March 10, 2014 Report Share Posted March 10, 2014 Can't complain about $30! 1 Quote Link to comment
zat Posted March 11, 2014 Author Report Share Posted March 11, 2014 Can't complain about $30! yeah man. labour here is considered cheap. full reupholstery incl headliner, seat covers, carpeting and boot lining is approx $500. 1 Quote Link to comment
KlassicMotion Posted March 11, 2014 Report Share Posted March 11, 2014 I do upholstery, and I'd probably have that just in materials! 1 Quote Link to comment
zat Posted April 7, 2014 Author Report Share Posted April 7, 2014 i've been busy (and lazy, mostly). not much work done except for procuring a few stuffs. i have this decal reproduced. what do you guys think? got this NOS front turn signal (without box though) with some storage wear. can anybody advise whether this is correct for our 510? According to the part number 25540-B5000 its for 620. Kindly advise. Thanx Quote Link to comment
Rock__maN Posted April 7, 2014 Report Share Posted April 7, 2014 after 2 days and $30, here's how it looks: compared to: its hard to find a proper dash restorer here. so i had to opt for rewrap. good enough for me, for $30. can you suggest me to procedure of repair this item ? thank you Bro. Quote Link to comment
zat Posted April 7, 2014 Author Report Share Posted April 7, 2014 can you suggest me to procedure of repair this item ? thank you Bro. hey man, sorry couldn't be much help. i just choose the material and the upholsterer did the rest. Quote Link to comment
zat Posted May 22, 2014 Author Report Share Posted May 22, 2014 Detailed using silver paint marker. Pic shows before and after. 2 Quote Link to comment
