Project Datstang
Bory
  • Replies 1.7k
Bory try your wash mix on scrap wood to get the consistency the way you want it.  When you have the wash thinned the way you like then try on scrap wood putting different amount of coats on to get the desired look and depth of color.
You are closing in on the end of this build and all the way through the build you have done stellar design and workmanship.  Beautiful truck!!!
  • Like 3
Well I'm pretty happy with the glass!
If your asking about door mirrors, I'm using the rod ones that hang off the frame, also thought it would be cool to keep the antenna in the stock location. 680F86AF-6624-4858-9334-CD907FEBD246_zps
Like i was running here
Wow !!!! that glass is the cats meow !!!!
Very sweet , was that expensive ? is it the same replacement glass just glued in ?
Your truck is very close to being finished ...............your so fortunate to be at this stage , great job !!!
DF-
You are correct
Winshield was over 300 and install was like 200, but i was quoted over 500 for just the winshield from some shops,
The install was a bit more work cuz he had to sand it down to fit the tight areas. I did the same to the factory glass when I welded the receiver smaller.
