TENDRIL Posted April 18, 2014 Report Share Posted April 18, 2014 i hover over the picture, right click, copy img. URL, click on the little Polaroid square paste in the bar and press ok you have to post one pic at a time but it works every time. unless the photo is not hosted than it say you cant use that img. extension 2 Quote Link to comment
housew Posted April 18, 2014 Author Report Share Posted April 18, 2014 tendril, that doesn't work for me either. Browser just freezes after i imput the url for the image. I just downloaded a different browser (motzilla) and im going to try that. 2 Quote Link to comment
housew Posted April 18, 2014 Author Report Share Posted April 18, 2014 woot woot, mozilla for the win. im hoping to make some progress on the dime tomorrow, and should have a bunch of pics to post up on monday. thanks for walking me through it guys! Just another reason IE isn't my favorite. Quote Link to comment
housew Posted April 18, 2014 Author Report Share Posted April 18, 2014 AND boost gauge ordered. i have a feeling the PO had the boost turned up a bit, but i don't know how high with no gauge. Gonna fix that while im in there plumbing and wiring for the rest of the gauges. Detailed gauge cluster build will be posted, with many pics now that i know how Quote Link to comment
housew Posted April 22, 2014 Author Report Share Posted April 22, 2014 I have some parts in the mail, should get my boost gauge and tinted plexi (for gauge panel) on thursday, and my diamond racing steelies should be here friday :) and a random engine bay pic now that i know how :) 2 Quote Link to comment
housew Posted April 22, 2014 Author Report Share Posted April 22, 2014 a few shots of the new steering wheel and hub. Its a nice racemark (made back in the 60/70s for porsches, and got it for my 914, but i like the wheel in that car so it found a home here). Eventually i'd like to get a thick wooden nardi, but this will fit the bill for a while. BOSS hub kit and horn button that fit well. Suprizing how easy a job it actually was. Everything fit together wel URL=http://s1360.photobucket.com/user/willhouse207/media/20140419_092055_zps46fab8ee.jpg.html][/url] Quote Link to comment
housew Posted April 22, 2014 Author Report Share Posted April 22, 2014 now on to the gauge cluster build.... Car came to me with no gauges. It had the factory 69 gauge cluster, but nothing was hooked up. I was thinking of going the autometer route, but didn't like how hack it would probably look since i'd have to remake everything and have tiny gauges. I ended up getting the intellitronix 5 gauge panel (they make a 6 gauge with tach, but it was too wide to not hack). I plan to run the intellitronix gauge where the stock cluster was, a boost gauge where the a clock would go it my datto was fancy, and a tach mounted on the steering column. I'm going to worry about the tach after i get the others physically mounted, wired up, and functioning. can check em out here. http://intellitronix.com/5-gauge-panel.html the end goal it to have blue led gauges for temp, oil pressure, voltage, speed, odometer, blink indicators, and boost. Going to use the stock bezel and the whole panel will appear to be just black when the car is off. coupla pics of the stock gauge cluseter from different angles so you know what im working with: In the last picture you can see 4x phillips head screws holding the gauge panel onto the bezel, and 2x more holding the clock blank onto the bezel. Remove those and it all comes apart Quote Link to comment
housew Posted April 22, 2014 Author Report Share Posted April 22, 2014 cluster out, bezel out, glass out and left with just the bare surround, which is about all i will be useing. turns out the "glass" is just flat plastic, so that can easily be replaced. Quote Link to comment
housew Posted April 22, 2014 Author Report Share Posted April 22, 2014 next i dropped $1.25 on some acrylic down at the local hardware store (big spender) and mocked it up to fit had to make cutouts to clear the ribs between the gauges and the clock, but it worked out nice because they locate the acrylic side to side. I then shaded the acrylic with tail light tint to match the acrylic intellitronix sent with it, but it looks kinda shitty. I ordered some tinted acrylic that should be here thursday. I figured out the mounting brackets for the gauge panel itself, but i need to wait untill thursday for the boost gauge to show up so i can figure out mounting for that as well. Then its on to installing the sending units and wiring it up. Quote Link to comment
housew Posted April 24, 2014 Author Report Share Posted April 24, 2014 I received my boost gauge and tinted acrylic in the mail last night. I gutted / destroyed the boost gauge so its just the electrical panels now, and i have the mounting theory figured out. I need to pick up some longer screws and spacers at the hardware store tonight and im hoping to be able to fab most of it up. Ill probably end up changing something and requiring an additional run to the hardware store, but thats life. I also did some figuring on the sending unit mounting. For the oil pressure sending unit, I plan to replace the stock oil pressure sending unit. The red top sr20det's oil pressure sending unit is just a 6psi dummy light. Comes on if it drops below 6psi, and doesn't tell you much else. It doesn't talk to the ECU at all so im going to replace it with the intellitronix sending unit. Issue is the nissan sensor is 1/8 BSPT (brittish standard pipe taper) and the intellitrinix is 1/8 npt. I could probably get away with threading it in but it wouldn't be right, would probably leak, and i can't really use tape since the sensor grounds through the threads. Solution is an adaptor, mcmaster car has them (PN 4860k141) for $4.99 so i need to order that. For the water pressure sending unit the red top sr20det has 2 different ones, both right by the thermostat housing. One is for the ECU, and one is for the gauge. I can in theory replace the gauge one, or just leave it there and add the sensor to a coolant hose, or tap a new hole somewhere. The stock one uses an m12x1.25 thread, and the new intellitronix unit is 1/8" npt. I can get a small "splice pipe" with a bung for a rad hose, or an m12x1.25 x 1/8npt adaptor for ~$15, and since i like the stock placement better than the hose, i plan to go that route. Hopefully ordering both sensor adaptors tonight. boost gauge came with a sending unit I tee into a line, still need to figure out where that goes (i would assume right off the throttle body on the fuel pressure regulator line?) Fuel level sending unit works off a universal ohm signal and i believe it is configureable. Should work with the stock sending unit in my tank if thats any good. I need to figure out how to test, and test that. the turn signal indicators, volts, lights / dimmer should all just be finding the right wires from the factory plug. so that sould be easy enough Quote Link to comment
housew Posted April 24, 2014 Author Report Share Posted April 24, 2014 just got an electronic letter from the south pole (or whereva brown santa lives) saying that UPS dropped my rims off today! so excite to ditch the desk job and check em out Quote Link to comment
paradime Posted April 24, 2014 Report Share Posted April 24, 2014 Oh I know that feeling all too well. Quote Link to comment
housew Posted April 25, 2014 Author Report Share Posted April 25, 2014 BAM. look at that stagger! :) hope they fit. 15x7+0 and 15x8+12 Quote Link to comment
housew Posted April 25, 2014 Author Report Share Posted April 25, 2014 couple pics of me destoying / harvesting a cheap digital boost gauge nice and new first gentle break done by prying with a screw driver bunch more by grabbing and tearing the plastic with dykes (i love calling pliers dykes) all harvested and ready to go Quote Link to comment
housew Posted April 25, 2014 Author Report Share Posted April 25, 2014 got a new peice cut out of tinted acrylic instead of the lens tint sprayed BS i had before started making the mounting brackets to hold the gauges to the bezels. I'm a nerd so i drew em up in cad, printed them out 1:1, and used that to make them and you can see how dark the new tinted stuff is. Almost a perfect match for what intellitronix sent with the gauges 1 Quote Link to comment
housew Posted April 29, 2014 Author Report Share Posted April 29, 2014 gauge cluster is all physically done, working on figuring out the the wiring / plumbing. things on order. dunlop direzza dz102s in 195/50r15 Front and 205/50r15 rear m12x1.25 to 1/8npt adaptor for the water temp sending unit 1/8bspt to 1/8npt adaptor for the oil pressure sending unit. also put another 60ish miles on the car on sunday. Stupid fun to drive now that the frost heaves are gone. Lovin it :) Quote Link to comment
housew Posted May 1, 2014 Author Report Share Posted May 1, 2014 So I started wiring the cluster tonight. Got it powered up and the turn signal indicators working. I'm still waiting on the sending unit adaptors so all I had wax the fuel gauge. I was trying to figure out the ohm range for the fuel sender unit and...... I closed the trunk with the keys in it. Now I need to remove the rear seat to get at them. Found that out so hopefully getting in there tomorrow. AND I didn't really get anywhere with the fuel sending unit. Still have some learning to do. Where do I test ohms between? Seems like the whole tank isn't grounded at all. It's mounted on rubber and 0 continuity between the tank and new bat cable/terminal Quote Link to comment
housew Posted May 1, 2014 Author Report Share Posted May 1, 2014 got the rear seat out this morning. I was super worried about it. Took <5 minutes and was super easy. For the rear seat bottom you just lift up on the front edge and pull out. With the bottom out you can see 2x cheese / phillips head screws tolding the rear seat back down. remove those and slide the seat up out of its hooks, and voila, seats are out. My car has some fiber board behind the seat to seperate the trunk from the passenger compartment. I'll remove that after work, fish my keys out, and get back to work :) tires should also be in today. looking forward to getting those in and seeing if they fit or what i need to beat modify to get them too. Quote Link to comment
Nuclear Water Boy Posted May 1, 2014 Report Share Posted May 1, 2014 Hey Guys Not new here as my last user quit working for whatever reason. Anyway nice to see Datsun Mainers so close. I'm in Danville, NH own a '69 2-Door 510 with S14 NA SR20DE. Your talking about a get together sounds like fun but middle of the week is an issue for me as I play a lot of Racquetball during the week. Maybe some weekend we could all meet up and take a drive or just hang or both. As soon as this weekend I'll start my ritual of checking out the 510 for the drive to Summit Point West Virginia I've been doing since '99. It'll be another great weekend of camping, racing and hangin with a bunch of other 510/Datsun heads, A splended time is guarenteed for all. Lou Quote Link to comment
housew Posted May 1, 2014 Author Report Share Posted May 1, 2014 hey lou. i heard about summit point, i'd love to make it out there but it wont be happening this year for me. I have a baby due (actually past due now) so im sticking really local for a while. Next year is a strong possibility though. I'm down for a meet up some time soon though. Still to this day i think i've only seen 4 510s in person in my life, including mine :p Quote Link to comment
Nuclear Water Boy Posted May 1, 2014 Report Share Posted May 1, 2014 Of course you'll stay close with a baby taking her time<---Her Time B) Congrats. Summit Point will be around next year so maybe all us Datsun guys can can caravan down, that would be very cool. Used to do that with Chris of Maine. Oh and it doesn't have to be a 510 no sir!!! any Dat will work even if you don't have a Dat it'll work. Quote Link to comment
housew Posted May 1, 2014 Author Report Share Posted May 1, 2014 nice! I thought the summit point event was spec 510 and was pretty 510 centric. My 510 is a 69 4 door (obviously since this is my build thread) but i also have a 72 240z and a 74 260z both orange and very stock. I should be able to drive something down there if i can find the time to make it. I keep hearing about this Chris guy, hes supposed to be from my town (gray maine) but i haven't run into him yet Quote Link to comment
housew Posted May 2, 2014 Author Report Share Posted May 2, 2014 Not a lot to report. Got the keys out of the trunk. Thinking of removing the parcel shelf and recovering it now that i have access to it, but im still not sure how the shelf itself comes out. Is it just held in there by 40 years of sun and decomposing or are there clips / screws? (rear seat is out) also received the oil pressure sending unit adaptor from summit. So i can get started wiring that in :) Oics of the gauge cluster all together. OffonI need to do a shroud of sorts around the boost gauge to contain the light a bit better, but that's the idea.disclaimer: no 69 datto parts were hurt in the making of this cluster all plug/bolt in so far, please forgive the floral screwdriver. My tools have to be outside, the "inside tools" belong to my wife haha 2 Quote Link to comment
solo Posted May 2, 2014 Report Share Posted May 2, 2014 Not a lot to report. Got the keys out of the trunk. Thinking of removing the parcel shelf and recovering it now that i have access to it, but im still not sure how the shelf itself comes out. Is it just held in there by 40 years of sun and decomposing or are there clips / screws? (rear seat is out) also received the oil pressure sending unit adaptor from summit. So i can get started wiring that in :) Oics of the gauge cluster all together. Off on I need to do a shroud of sorts around the boost gauge to contain the light a bit better, but that's the idea. disclaimer: no 69 datto parts were hurt in the making of this cluster all plug/bolt in so far, please forgive the floral screwdriver. My tools have to be outside, the "inside tools" belong to my wife haha Bad ass cluster there man. Good shit can't wait to see it lit up in the car keep up the good work. Quote Link to comment
Nuclear Water Boy Posted May 2, 2014 Report Share Posted May 2, 2014 nice! I thought the summit point event was spec 510 and was pretty 510 centric. My 510 is a 69 4 door (obviously since this is my build thread) but i also have a 72 240z and a 74 260z both orange and very stock. I should be able to drive something down there if i can find the time to make it. I keep hearing about this Chris guy, hes supposed to be from my town (gray maine) but i haven't run into him yet Well yes and no in that lots of 510s yes but not neccessary. We've had Z cars, a Celica but with all Nissan running gear, BMWs, one Honda,,,One!!! You'd be very welcomed in any Z car. Chris is actually in Mechanics Falls. He sold his Camo 510 to Fisch<--spelling? who has had it for a few years and is yet to make Summit Point. Summit is a blast otherwise it would have faded years ago. But we always have fun and the night time venturing around the track through the woods on the infield finds you in a camps with open arms and opening beers :thumbup: Quote Link to comment
