EDITED :) looking at picking up a Goon
B210GX
  • Replies 30
That looks very nice for being in a junkyard so long.
Yes I was very surprised when I found it.   (not in the import section)
Wish the hood was in as good of shape as the rest of the car,  Going to have to find one.  hint hint
I may be able to make it work out. Its pretty rough
Pulled whats left of the motor out (anyone need a smog pump?) it turns free .  The trans nearly came out with it, without unbolting the crossmember.  The mount is toast.
 Crawling around under it, I found forklift marks on the left rear pass. floorboard.  Not punctured thankfully.
Then I saw these
Are they supposed to one piece or just pressed in?
Tires and wheels mounted, looks like they will fit well.
And the newly aquired dent the POS yard owner installed for me
Thats all for today  :)
I got alotta junk but no hood
On another note there should be a late summer get together in Ellensburg/Vantage/George or Moses lake/Euphrate ( for the swim areas if it's baking hot) sometime.. If it was on the 90 we all could travel a bit but nobody has to do 6 hours each way. Probably have to work with people quite a bit on dates as we all would be traveling ..
