BajaScout Posted January 25, 2014 Report Share Posted January 25, 2014 Anyone know what thermostat and gasket will work for a 65 320? Quote Link to comment
datzenmike Posted January 25, 2014 Report Share Posted January 25, 2014 Take the old one with you or the top rad outlet and test fit them. If the thermostat mounts on it's side it should have a jiggle valve towards the top to bleed any trapped air. Back then most thermostats were about the same size. I would imagine around 180F Quote Link to comment
BajaScout Posted January 25, 2014 Author Report Share Posted January 25, 2014 King Rat, Thanks. Looking at the housing it lays flat. Quote Link to comment
Conner Posted January 26, 2014 Report Share Posted January 26, 2014 Try Beck Arnley 143-0685. That's a 180 degree thermostat for a J13 engine 520 truck. It should fit and has the jiggle valve. $7 from Rockauto. The housing gasket is B/A 039-0036. Quote Link to comment
datzenmike Posted January 26, 2014 Report Share Posted January 26, 2014 Good price. I wouldn't go any cheaper on this vital part. Quote Link to comment
MikeRL411 Posted January 26, 2014 Report Share Posted January 26, 2014 I have found that most aftermarket thermostat gaskets sold for early Datsuns are too thin on the outside to the thermostat recess in the fitting, a Chrystler corporate [usually stocked as a Plymouth or Dodge] thermostat gasket fits the thermostat and the mounting holes and has the requisite edge thickness to properly seal. They don't need Permatex, but I apply anyway! Quote Link to comment
BajaScout Posted January 26, 2014 Author Report Share Posted January 26, 2014 Appreciate all the info. I have several other items to order from RockAuto, so I will put an order in today. Quote Link to comment
ggzilla Posted January 26, 2014 Report Share Posted January 26, 2014 Beck/Arnley has quality stuff so if you can find a B/A thermostat for less than $7, don't be afraid to go for it. The quality is what matters, not the price. Quote Link to comment
datzenmike Posted January 26, 2014 Report Share Posted January 26, 2014 Quality first. Presumably a $3 Chinese POS WallMart one will have less quality control than a $12 one. What's a boil over worth to you? Quote Link to comment
