Pootermobile Posted January 11, 2014 Report Share Posted January 11, 2014 I've had my Datsun 610 for a few years now but had it sitting in the yard getting a bit more rust and dirt :( now that I have time and money I'm gonna make it driveable again. I can't wait to be able to drive it again! Needs brakes, tires, and tuneup. Bigger plans are body work. 1 Quote Link to comment
datzenmike Posted January 11, 2014 Report Share Posted January 11, 2014 Two door tastiness... get at er son! 3" lowering blocks, zx 15/16" master and strut swap with trimmed springs, 5spd swap....... Quote Link to comment
Bentaxlebob Posted January 11, 2014 Report Share Posted January 11, 2014 Two door tastiness... get at er son! 3" lowering blocks, zx 15/16" master and strut swap with trimmed springs, 5spd swap....... No need for lowering blocks. The 610 has independent rear suspension (IRS) 4 Quote Link to comment
Pootermobile Posted January 12, 2014 Author Report Share Posted January 12, 2014 Thanks guys :) I want to also fix the speedometer it doesn't mark anything. What could it be? I know basic mechanical work. Quote Link to comment
bonvo Posted January 14, 2014 Report Share Posted January 14, 2014 cables broken is the most likly cause Quote Link to comment
Pootermobile Posted March 4, 2014 Author Report Share Posted March 4, 2014 Woohoo! Got a couple of much needed window regulators :) Quote Link to comment
datzenmike Posted March 4, 2014 Report Share Posted March 4, 2014 Two door tastiness... get at er son! 3" lowering blocks, zx 15/16" master and strut swap with trimmed springs, 5spd swap....... No need for lowering blocks. The 610 has independent rear suspension (IRS) That's embarrassing. At 3Pm I have no excuse. Thanks guys :) I want to also fix the speedometer it doesn't mark anything. What could it be? I know basic mechanical work. The speedo cable is on the driver's side of the 4 speed transmission while the automatic is on the other side. Inspect the cable under the car for damage. If bent, crushed or if the outer covering is cut open in any way it's best to replace. Water can get in and freeze in the winter and the transmission will twist it apart. The end of the cable is knurled and can usually be twisted off or gently use pliers to loosen. You will have to loosen and move the dash gauge cluster to unscrew the interior end. Quote Link to comment
Pootermobile Posted July 27, 2014 Author Report Share Posted July 27, 2014 Hey everyone I'm in need of front driver side window regulator. I think some teeth got broken off :( Anyone on here have one for sale? Quote Link to comment
datzenmike Posted July 27, 2014 Report Share Posted July 27, 2014 This is the 610/710 forum for discussion of the 610/710 cars. All buying or selling is done in the CLASSIFIEDS... http://community.ratsun.net/classifieds/category/9-body-and-interior/?sort_key=date_added&sort_order=desc Please post a wand ad there. 1 Quote Link to comment
Pootermobile Posted July 27, 2014 Author Report Share Posted July 27, 2014 This is the 610/710 forum for discussion of the 610/710 cars. All buying or selling is done in the CLASSIFIEDS... http://community.ratsun.net/classifieds/category/9-body-and-interior/?sort_key=date_added&sort_order=desc Please post a wand ad there. Thank you very much :) posted there Quote Link to comment
