Rebirth of EVIL Z - LS1/T56
EVILC
Been slacking for a year but finally moved my 260z that I bought to replace my 240z into my buddies garage, I plan to have her up and running in a few weeks! More details are coming but pics will do for now:
  • Replies 25
  • 1 month later...
Ugh... I'm quite envious of the parts-porn that is your project. Is it an illusion or is the LS1 really that short (shorter than an L series)? Forgive my ignorance, I've never had a V8 although I absolutely admire them. What's the story on the engine? Looks promising!
most v8's are a bit shorter than l6's, they're 2 cylinders shorter, so in theory they should amost always be shorter. not sure on the larger displacement v8's, but a 350 is significantly shorter. that's why the best track z's are usually v6 equipped rather than inline 6, they have fantastic weight distribution.
  • 1 month later...
  • 2 months later...
  • 1 month later...
So car was sent out to have some welding done, replacing a floor - new rails tied into my frame kit - roll bar mod for seat belts - seats mounted lower in the car - pdk custom down bars to tie into swap bars and a few other things:
10661818_756008945349_494394349536730396
10710341_756009005229_699139522973023369
68955_753004601079_608215751103548508_n.
10624899_750314057949_2055213346683931311908069_750314013039_6068957181591233264
Awesome and inspiring post. I may have a few questions about your fuel setup. I want to retain the stock fuel tank in my 71 240Z. I was thinking about aeromotives stealth system. I want to eliminate fumes from the cabin if possible. I will be going 2JZ, so its a little different. I wanted LS but the 2JZ stuff worked out cheaper.
