windowless66 Posted March 8, 2015 Author Report Share Posted March 8, 2015 I'm from australia swell, melbourne to be exact and i drive a 76 620 daily, theres heaps of 6 lug wheels here try looking for 4x4 wheels Thanks Eccles Yeah I found a nice set in melbs, bidded and won and the guy tried to charge me more. I'd went to town on paint too. Bit discouraged after that and now I like the sunraysias :P I do have another rough tub that I have to pick up that's rough enough to cut for z flares so I'll be looking again before too long. 1 Quote Link to comment
Eccles Posted March 8, 2015 Report Share Posted March 8, 2015 run the sunnies if you like them mate, where a bouts are you located? 1 Quote Link to comment
Eccles Posted March 8, 2015 Report Share Posted March 8, 2015 theres a few of us 620 owners around melb 1 Quote Link to comment
windowless66 Posted March 9, 2015 Author Report Share Posted March 9, 2015 I'm north central, a bit out of Bendigo. If you guys have a bit of a meet let me know and I'll try to make it there. 1 Quote Link to comment
Eccles Posted March 9, 2015 Report Share Posted March 9, 2015 we had one last weekend in nagambie mate 2 Quote Link to comment
Jester Posted March 9, 2015 Report Share Posted March 9, 2015 Those are bad ass! 1 Quote Link to comment
Eccles Posted March 9, 2015 Report Share Posted March 9, 2015 Thanks Eccles Yeah I found a nice set in melbs, bidded and won and the guy tried to charge me more. I'd went to town on paint too.Bit discouraged after that and now I like the sunraysias :P I do have another rough tub that I have to pick up that's rough enough to cut for z flares so I'll be looking again before too long. if ya move them on hollz at me 1 Quote Link to comment
windowless66 Posted April 6, 2015 Author Report Share Posted April 6, 2015 Finally picked up the donor 620. Good enough Tub for z flares, scored an under-dash parcel shelf and has a J16 that will get a freshen up for the daily. Forgot to get a before photo :P 3 Quote Link to comment
Eccles Posted April 6, 2015 Report Share Posted April 6, 2015 I'm looking for an interior light cover if you have one 2 Quote Link to comment
Charlie69 Posted April 7, 2015 Report Share Posted April 7, 2015 There is a guy here on Ratsun that is making them with a 3d printer. 1 Quote Link to comment
windowless66 Posted April 7, 2015 Author Report Share Posted April 7, 2015 I'm looking for an interior light cover if you have one I might have a cover I'll have a look get back to you in the next couple of days ;) A 3d printed one would be cool though. 1 Quote Link to comment
Charlie69 Posted April 7, 2015 Report Share Posted April 7, 2015 Here is a link to his thread on 3D printed light lenses. http://community.ratsun.net/topic/65269-3d-printed-dome-light-lens-for-your-620/ Quote Link to comment
Jester Posted April 8, 2015 Report Share Posted April 8, 2015 I'm looking for an interior light cover if you have one I am going to assume that you have a standard cab. Very few King Cabs were titled as "76's. 1 Quote Link to comment
Eccles Posted April 8, 2015 Report Share Posted April 8, 2015 I am going to assume that you have a standard cab. Very few King Cabs were titled as "76's. sure is standard cab long tray 1 Quote Link to comment
windowless66 Posted April 18, 2015 Author Report Share Posted April 18, 2015 Pretty sure I was followed home last night.... 5 Quote Link to comment
windowless66 Posted June 1, 2015 Author Report Share Posted June 1, 2015 Finally getting around to changing the engine, getting undrivable with no compression. Had to downshift uphills and almost impossible to start cold with the sidedrafts. Prepping the patient Halfway there. Unimpressed 4 Quote Link to comment
Eccles Posted June 4, 2015 Report Share Posted June 4, 2015 i have a very similar rack 1 Quote Link to comment
windowless66 Posted June 4, 2015 Author Report Share Posted June 4, 2015 Yeah I made my rack just cut down a sedan one :) Quote Link to comment
windowless66 Posted July 8, 2015 Author Report Share Posted July 8, 2015 Rookie mistake! Finally had everything hooked up turned the key and bent a rod and valve :/ Mustn't have had the pushrod seated right. Next time I'll be more pedantic and set all my valve clearances before firing up. I've gotten away with it too many times before and it's finally caught up with me. Funny had a bit of a week of it Mower cord broke, left the brake on on my trailer and cooked the brakes and now this :) Too scared to take the head off...Don't want to see if there's a hole in the piston :P Quote Link to comment
SPIDERSHACKOV Posted July 8, 2015 Report Share Posted July 8, 2015 The valves clearance should have been checked when the motor was going together. Correct. That Ius one Iif the things I double check before buttoning everything up. 1 Quote Link to comment
windowless66 Posted July 31, 2015 Author Report Share Posted July 31, 2015 Bought a 78 model with ball joints for a body swap, because its Australia we were lucky enough to have balljoints and drum brakes. Been asking around and the 720 disk spindles and calipers are supposed to be a bolt on upgrade. Another guy has done the swap on his Kingcab over here. Early days but the cab looks in better condition than mine could end up being a tub swap yet :P 1 Quote Link to comment
windowless66 Posted August 15, 2015 Author Report Share Posted August 15, 2015 Shes back on the road again! Swapped all the J15 valves into the J16 lapped them in. Did all the valve clearances TWICE using the rule of nine. Then took it for a lap of town just as the sun went down. Today was a good Day! 1 Quote Link to comment
windowless66 Posted October 4, 2015 Author Report Share Posted October 4, 2015 76' has been running well and still doing the daily duties. Getting bits ready for the engine swap in the 78. 720 stubs,callipers and disks, a 63A gearbox, sss carb setup and L20b engine. 1 Quote Link to comment
windowless66 Posted October 31, 2015 Author Report Share Posted October 31, 2015 Yesterday was my last Day with the '76. New chapter for the 620 with a new owner. Funny feeling not sadness, but kinda like when your cat dies. Feels strange that its not around anymore but alot of positives to the situation too. Quote Link to comment
Eccles Posted October 31, 2015 Report Share Posted October 31, 2015 be cool to see what dale does with it 1 Quote Link to comment
