toyota1515 Posted November 22, 2013 Report Share Posted November 22, 2013 Weekend Cruiser here! 9 Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 Custom front brakes 1 Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 Mr. Gasket V-Gate shifter, Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 give my car some love on the floor boards before installing the new carpeting i got laying flat on my guest room king size bed! 1 Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 Main studs and gridle mocked up so the machine shop can do the machining on the block like align hone, bore, decking, block plate honed, also the crankshaft job and balance the rotating assembly with fluid dampr and billet flywheel, Clutch kit from spec clutches ordered, ARP head bolts damper bolt, flywheel bolts ordered with a melling HV oil pump wit bolt set, all from Mancini, Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 Here is the clutch kit from SPEC Clutches, it looks serious holding power rated at 700+ HP so i should be ok with my goal of 550HP Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 Simple Electronics are here long time ago just i didnt have a chance to show em to you guys, A new MSD Pro Billet Distributor, MSD Digital 6 with 2-step, timing retard rev limit and many other things i dont know yet how to use, plus a MSD blaster SS coil, As well as the new brake plumbing, the complete brand new wiring for the whole car from head lights to tail lights, Melling HV oil pump, Oil pump fasteners, ARP Head bolts, ARP harmonic balancer bolt, Mancini Flywheel bolts, roller pilot bearing And 3 bolt Mancini cam snout bearing, Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 Here is a good update, I get all my parts from the machine shop and all of the tolerances just mike perfect so soon i will be putting together this puzzle! Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 I start with the engine assembly today and already made a mistake by ordering the wrong piston rings, my probe pistons take the 1/16 first and second rings and i order the 5/64 by mistake, my fault for not checking before ordering, thanks to the good people of Mancini Racing, and i return the wrong rings and the right ones are already on their way here, super customer service. So i just get the crank and girdle installed and torqued down to 110 Ft. Lbs. and sealant plus the rear main seal also installed and sealed, hope no leaks cuz it will be a pain in the ass to do it in the car. here couple of pictures of it on its way to be an engine again since the late 70's! 1 Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 Well i did a little more today on the engine, file fit rings to abuse type specs, and then got to stop cuz my only facking T45 torx bit is the broken one and can't torque down the timing chain sprocket, so bag it and till next time i got a chance. Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 Got the valvetrain together and balancer torqued down with the new ARP Bolt Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 I get rid of the 325/50's and install some 275,60's bias ply street tires, and i do the Plasti-Dip black paint on the wheels! Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 Engine finished! Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 There was no body repairs, it was a minitub work, to widen the rear tire wheelwell to fit the fat rear tires, i also include a leaf spring relocation work in it for tire fitment too! here are couple more pictures of minitubs fab and subframe connectors installed! Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 Here is the leaf spring relocation job to tuck in the leaf springs for tire clearance, Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 EFI elbow in place and ready to mock up the injectors bungs! 1 Quote Link to comment
datzenmike Posted November 22, 2013 Report Share Posted November 22, 2013 Bought a new '70 Dart 340 back in the day. By '72 I think that motor was long gone. The factory manual showed a 383 option. There were 360s is this one? Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 This one was a slant 6 from factory, i took it to the recycle place in running condition! Quote Link to comment
DRIVEN Posted November 22, 2013 Report Share Posted November 22, 2013 I like this alot. Quote Link to comment
'70dime Posted November 22, 2013 Report Share Posted November 22, 2013 Hey I'll bar hop in this thing! Quote Link to comment
datzenmike Posted November 22, 2013 Report Share Posted November 22, 2013 This one was a slant 6 from factory, i took it to the recycle place in running condition! . So what I'm asking is what is it now? Did I miss it somewhere? 360? 383? Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 . So what I'm asking is what is it now? Did I miss it somewhere? 360? 383? Oh now is a 440 punched to .40 over for a whoping 452 CID! Quote Link to comment
jrock4224 Posted November 22, 2013 Report Share Posted November 22, 2013 wow im so glad I clicked on this and im not even a dodge fan ...... sick build ....... I love the black wrinkle pc'd engine tins Quote Link to comment
Eagle_Adam Posted November 22, 2013 Report Share Posted November 22, 2013 bad ass!!! Quote Link to comment
toyota1515 Posted November 22, 2013 Author Report Share Posted November 22, 2013 Thanks guys! Quote Link to comment
