* * * * * 1 votes
Freebird
  • Please log in to reply
115 replies to this topic
#41 volkswagner
volkswagner
    SAM!!!!!!!
  • Senior Member
  • PipPipPipPip
  • 370 posts
Posted 14 February 2015 - 10:53 PM
6 months since my last post, whoops. Lets catch up.
I couldn't stand the smoke the new rebuild was putting out.
All indicators pointed to bad rings even though they were brand new. Back to the tent.
I didn't take any pictures of this job. It's a real pain to get a hold of a cherry picker and scary to set it up on soft dirt.
I decided to leave the block in for the re-ring job. There is some discussion in the ring sticky thread about doing this and everyone seems to think it is a waste of time.
After pulling the motor and doing rings and then a month later leaving the block in and doing rings, my opinion is;
If all you are doing is rings (no honing, crank replacement, etc.) it was WAY faster/easier for me to leave the block in the car, pull the head, and drop in the new piston setups.
I've driven the motor a few hundred miles now with no Smoke. Bad aftermarket rings, improper installation? not sure which one.
#42 volkswagner
volkswagner
    SAM!!!!!!!
  • Senior Member
  • PipPipPipPip
  • 370 posts
Posted 14 February 2015 - 11:16 PM
As I said before, I was getting some major drive line rub due to my ride height.
Here is my initial tunnel cut out.
This hole was not large enough, it had to be widened.
Here is the cover panel that got welded in.
I only wanted to modify under the seat.
After driving around some more, it turns out this is not sufficient.
Due to the larger diameter wagon driveling, there is still rubbing under acceleration. It rubs the tunnel just in front of the seat bulkhead.
Maybe I will do more tunnel mod.s later on. Right now I plan to angle lowering block and hammer in the problem area.
For those curious, I currently have stock main leaf, second leaf, and third leaf as well as another second leaf flipped and .5" lowering blocks with 3 degrees of angle.
That gets me sitting a couple inches higher in the rear than whats shown above.
#43 volkswagner
volkswagner
    SAM!!!!!!!
  • Senior Member
  • PipPipPipPip
  • 370 posts
Posted 14 February 2015 - 11:35 PM
Next I tackled the interior...
After gutting and cutting out rot, This was my starting point.
patch panels welded in.
Grind away the rust.
Mask, lay down epoxy primer on the bare metal, and apply aluminum window flashing to the panels without stock sound deadening.
The window flashing worked very well once some heat from a heat gun was applied. I couldn't smell any tar odor even while meting it with the gun, maybe I just have a bad sense of smell.
High build primer on the going to be visible areas and the color/clear, poor picture quality.
#44 volkswagner
volkswagner
    SAM!!!!!!!
  • Senior Member
  • PipPipPipPip
  • 370 posts
Posted 14 February 2015 - 11:53 PM
I wanted to route my power cable to the rear mounted battery a bit better.
I brought it through the firewall, into a grommet into the rocker panel, out of a grommet out of the rocker and clamped it down as it went to the back. The end result works well.
Next, came carpet.
I searched amazon and found a dense carpet padding that is made of fibers and is rubber backed for easier gluing.
http://www.amazon.co...0?ie=UTF8&psc=1
I was really satisfied with this and it was more than enough for my entire floor pan.
Then I went to Loews and got black outdoor carpet off of their giant rolls. It's a cheap option and the quality is cheap.
I installed the carpet with contact cement and burned out holes for the seat belt mounts and seat brackets using an old soldering iron. This left nice singed tight holes.
I got these miata seats off craigslist for a good deal. I am looking to do a brown/black interior so they fit the scheme nicely.
Mounting was straight forward. I just drilled holes in the miata rails to mount to the stock brackets, then drilled new holes in the floor to move the stock brackets to the appropriate locations for the miata rails. no pictures of this process.
This is the latest picture I have,
The interior is now mostly back together, I will have to get more recent photos.
#45 volkswagner
volkswagner
    SAM!!!!!!!
  • Senior Member
  • PipPipPipPip
  • 370 posts
Posted 15 February 2015 - 12:01 AM
A note on noise:
I am trying to reduce the noise level in the wagon since it was almost unbearable on the highway.
I will be tracking my progress using a decibel meter app on my phone. Is this highly accurate? no but I don't care, I just want relative measurements to tell me how much I'm improving, I think an app will be fine for this.
As It was prior to any interior work:
Cruising (60 mph on the highway)   91dB
Full throttle (from 60 mph on the highway) 93dB
Currently:
Cruising   87dB
Full Throttle 90dB
This is very noticeable in the car!
I think patching the rust holes in the floor right next to the exhaust leak really helped.
Other major contributors, nearly no door seals and 4 speed.
#46 Spoona_Jay21
Spoona_Jay21
  • Senior Member
  • PipPipPipPip
  • 1,116 posts
  • Cars:1981 BMW 320I, 2001 VW Cabrio, 1998 Lexus GS400
Posted 15 February 2015 - 01:36 AM
Love teh work on this man! I like how you routed your Battery lead, and what you used to fasten it all down. much better than alot I have seen. :thumbup:
What is your plan with all the green bits? is the car goin to go green in the future(may have just missed the explanation) or are you goin to pull the interior later for repaint? :confused:
oh! and A+ on the decibel ideer. most people just dynamat and call it good, and if it is too loud just deal with it :rofl:
#47 fisch
fisch
    Resident Ratsun Artist
  • User Administrator
  • 6,113 posts
  • Cars:1970 510 Wagon, 1959 Datsun 1000 sedan, 1972 Datsun 510 LZ22, Sold. 1971 PL521 Pickup
Posted 15 February 2015 - 07:15 AM
Great informative thread here!
#48 volkswagner
volkswagner
    SAM!!!!!!!
  • Senior Member
  • PipPipPipPip
  • 370 posts
Posted 15 February 2015 - 10:10 AM
Yep, the whole car will be green when finished, the engine bay, under hood, trunk jams and exposed interior metal are now all painted.
I am waiting until the entire exterior is body worked so I can do one uninterrupted spray there.
#49 volkswagner
volkswagner
    SAM!!!!!!!
  • Senior Member
  • PipPipPipPip
  • 370 posts
Posted 22 March 2015 - 12:54 AM
I got a bit more of the interior in, reinstalled the rear bench back rest (still need to modify the bench for the tunnel), put the rubber cargo mat back in and rear panels.
My helper wanted to be in the picture.
I came across a barn sale that had a pile of someones leftover project parts. In it was a few new in box Mopar seals.
For $5 I grabbed one that looked like it had potential for my trunk. Turns out they are about $70 new using the part number that was on the box.
It clipped on to the inner jam of my hatch area really well. and was long enough to wrap all the way around.
There was an extra bit of seal that sticks out on the inside and seamed useless. I started pullling and it tore of straight and easy.
Along the bottom edge I had to bend the seal into a 90 deg. This lets me slip the seal under the stock metal edge trim to screw it in place.
I was satisfied with the end result. I do have to slam my trunk hard to get it to latch but I'm OK with that.
I also finally got around to finishing my hood strut conversion.
I used mcmaster-carr Parts:  4138T55 and 9512K15
The 90 lb spring seems perfect to me, it falls on its own when shut but holds itself up when open.
I mounted mine a bit to close however so the strut bottoms out just before it is fully shut, it still works but I may address this later as it is pushing my hood out of whack a bit.
This is the neutral position, any higher and it opens, any lower and it shuts.
#50 volkswagner
volkswagner
    SAM!!!!!!!
  • Senior Member
  • PipPipPipPip
  • 370 posts
Posted 22 March 2015 - 01:43 AM
As I showed earlier, when I repacked my leaf springs I only got close to the ride height I wanted. The rear was still about 1.5" higher than the rear.
As well even though I cut out my tunnel, I was still getting drive line rubbing under acceleration and hard bumps.
I decided to try and solve both of these problems at once.
The solution has 2 parts. traction bars and angled shims.
I noticed that with my modified leaf packs (stock 1st, 2nd, 3rd leaf with flipped additional 2nd leaf bolted on top.) My leafs actually bend upward just slightly at rest.
I also noticed that the frame rail is breifly only a few inches away from the leafs in the front.
This gave me the idea to bolt a bar on top of my leafs that would extend forward to meet the frame rail.
Then when the diff rotates under acceleration or moves upward over a large bump, the bars would hit the frame and stop the drive line from grinding on the tunnel.
Here are the bars I cam e up with to fit my car.
They are made from 1.5" x 1.5" x .188" tube stock which calculates to only .006" of deflection given 120 ft-lb torque on the diff and a saftey factor of 20.
It's overkill but it was easy to get a hold of.
I would have preferred something wider so that it better matched the 2.375" leaf width.
I could supply the excel sheet for calculating the safety factor and deflection of a chosen material if anyone is interested.
The rubber bump stop is there to stop the rods from slamming the frame, they can also be adjusted to give more/less clearance to the frame rail.
The through hole is for the leaf pack bolt since I bolted these into the leaf pack so that they wouldn't move over time. Honestly, bolting them in sucked because without load the leafs bend the other direction. So you have to clamp the bars to the pack to straighten it out and bolt it in.
This hole is 15.5" from the end of the tube (which is flush with the end of the bump stop)
I used 9 degree spacers. In retrospect, 6 degrees would probably be better, there seems to be clearance for it and it would give better CV alignment.
This puts, the bar in the position shown. when at rest on the ground.
The video show at first me just pushing on the suspension which moves the leafs but does not engage the bars such as normal driving.
Then I jump on the rear which engages the bars such as over a large bump or under acceleration.
https://www.youtube....eature=youtu.be
and this is my current ride height. It is on 13's for reference.
#51 fisch
fisch
  • 6,113 posts
Posted 22 March 2015 - 06:34 AM
Great ride height! You are making me think about 13's for my wagon now.
#52 volkswagner
volkswagner
    SAM!!!!!!!
  • Senior Member
  • PipPipPipPip
  • 370 posts
Posted 22 March 2015 - 09:29 AM
I cut off the bump stop peanuts on the frame rails, so at this point there is still about 2in of suspension travel until the diff housing hits a trunk floor strut.
#53 TENDRIL
TENDRIL
    The Legend.
  • Senior Member
  • PipPipPipPipPip
  • 8,718 posts
Posted 22 March 2015 - 10:01 AM
this is awesome! did you use any glue?
Datsuns will 20 buck u to death
#54 volkswagner
volkswagner
    SAM!!!!!!!
  • Senior Member
  • PipPipPipPip
  • 370 posts
Posted 22 March 2015 - 10:30 AM
No glue, it has a metal core so it grips the frame well. We'll see if it wears in and need glue later.
#55 Dirttrack510
Dirttrack510
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,730 posts
  • Cars:1969 510 Goon Racecar, 1971 510 2dr. racecar, 1971 510 4dr. resto-project, 1971 4dr. 510 Ratsun
Posted 29 March 2015 - 03:48 PM
:poop: This build makes me wanna build my wagon :crying: It'd be a SERIOUS CHALLENGE though :sick:
#56 The Taterhead
The Taterhead
  • Senior Member
  • PipPipPipPip
  • 1,256 posts
  • Cars:'71 510 (mine),'72 510 (my sons), '01 Xterra currently
Posted 31 March 2015 - 08:52 AM
Looking good so far.
Just an FYI: that rubber backing on the padding you used can trap moisture under it.
Roads? Where we're goin' we don't need roads!
#57 Dirttrack510
Dirttrack510
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,730 posts
Posted 06 April 2015 - 10:50 AM
Hey, I just went to your youtube page. Is that a cassette player and you just slide your phone in to the slot and the tape player picks up the sound from your phone? Did you have to modify the car sterio?
#58 volkswagner
volkswagner
    SAM!!!!!!!
  • Senior Member
  • PipPipPipPip
  • 370 posts
Posted 12 April 2015 - 02:19 PM
Yep, that's exactly what it is.
I spliced a male audio jack into the tape player right before the amplifiers and then mounted it so that it would engage my phones audio jack when I pushed it in.
The phone plays signal to the amplifier, you can then use the tape player knobs to change the volume, bass, etc.
The tape player then sends the signal to the speaker. No modification to the car speaker system.
#59 volkswagner
volkswagner
    SAM!!!!!!!
  • Senior Member
  • PipPipPipPip
  • 370 posts
Posted 12 April 2015 - 02:20 PM
 Hmmm, didn't think of that. Good thing I don't live in a wet climate.... oh wait.
#60 volkswagner
volkswagner
    SAM!!!!!!!
  • Senior Member
  • PipPipPipPip
  • 370 posts
Posted 18 October 2015 - 07:55 PM
I managed to talk Jeff Hino into helping me respray the wagon.
And by respray I of course mean cut off both quarter panels, along with both rocker panels, fix the underlying rot, weld on replacements panels, body work all of the new panels, strip the roof to metal, remove the doors, remove the windows, strip and paint the jams, reinstall the doors, align all the panels, "fix" all of my shabby bodywork I have been doing to this point, block, the whole car and then spray.
We figured if we both did one side it couldn't possible take more than 2 or 3 weeks...
We started with the easy part, cutting the car to pieces.
Then welding on better panels.
More grinding away of 4 decades of resprays.
epoxy primer
it puts the filler on, it sands the filler off, it puts the filler on, it sands the filler off.
primer over the body work, paint in the jams, and rehang the doors.
align all the panels.
More bodywork, more primer.
more body work, more primer
wetsand
and finally... color.
https://goo.gl/photo...RxzqNXM627yjiN7
And several months later, its now time to reassemble.
