pondking Posted October 25, 2013 Report Share Posted October 25, 2013 Somebody have a suggestion I like how low hella 510's is but it seems he have to tinker with the kit looking to go sr20 (someday of course) Quote Link to comment
filthy forever Posted October 26, 2013 Report Share Posted October 26, 2013 theres lots of options open bud depends on how deep your pockets are. no matter what you do with a datty theres always gunna be tinkering so get used to it. 1 Quote Link to comment
KlassicMotion Posted October 26, 2013 Report Share Posted October 26, 2013 I'm going to try Techno Toy Tuning's (T3) setup. I've heard good things about the Troy Ermish camber plates, but I already have the T3 camber plates on the shelf. https://technotoytuning.com/nissan/510/front-weld-coilover-kit-datsun-510 Don't for get this too: https://technotoytuning.com/nissan/510/camber-plate-upper-hat-system-datsun-510 Here is another link: http://community.ratsun.net/topic/39512-strut-insert-and-rear-shock-guide/ Quote Link to comment
Ranman72 Posted October 26, 2013 Report Share Posted October 26, 2013 Techno Toy Tuning coil overs on the rear of my 510 and I love them 250 LB springs and set on 3 of 8 settings on the AGX shocks no sag and rides great TTT camber plates and adjustable tension rods not yet installed YOU CANT GO WRONG WITH TTT 2 Quote Link to comment
KyushaKai Posted October 27, 2013 Report Share Posted October 27, 2013 I've got everything T3 makes on the front of my wagon. Love it. I had Gabe at T3 weld the 280zx struts for coilovers and the only thing I have to say is that it drops it low. It's at max high and the front sits right in line with the top of the tire. I wouldn't say it's a complaint since that's right about where I wanted my front ride height, but for those who don't want to go too low, run 13's, etc. might have a problem with the T3 set up. Maybe call Gabe and ask him to weld the retaining ring up higher or weld it on your own. I'm super happy with them and if you're serious about going dumped, I could theoretically drop it another 4" if the exhaust didn't get in the way. 2 Quote Link to comment
q-tip Posted October 27, 2013 Report Share Posted October 27, 2013 First off car specs, 72 510 4dr with ka24de. I have the full ground control kit, (coil over sleeves, springs front camber plates rear coil covers) on 280zx fronts with koni adjustable inserts, futofab adjustable lca's and tension rods( the lca's and t.c. rods are not installed yet). I have has zero issues with anything, ride isn't harsh or bouncy, and it handles great. Quote Link to comment
KlassicMotion Posted October 27, 2013 Report Share Posted October 27, 2013 First off car specs, 72 510 4dr with ka24de. I have the full ground control kit, (coil over sleeves, springs front camber plates rear coil covers) on 280zx fronts with koni adjustable inserts, futofab adjustable lca's and tension rods( the lca's and t.c. rods are not installed yet). I have has zero issues with anything, ride isn't harsh or bouncy, and it handles great. How many lbs are your springs rated? Quote Link to comment
q-tip Posted October 28, 2013 Report Share Posted October 28, 2013 Fronts are 325 I don't remember rears but I think they're 250-300 Quote Link to comment
pondking Posted November 3, 2013 Author Report Share Posted November 3, 2013 How drastically will a roll cage improve suspension? the guy that i took my car to said its better to invest the money into the actual suspension than a roll cage Quote Link to comment
q-tip Posted November 10, 2013 Report Share Posted November 10, 2013 A pl510 chassis is suprizingly stiff, a lot more stiff than most factory spec sedans. Upgrade your suspension then drive it a bit, if its not stiff enough for you put a cage in, though I doubt you will need a cage for chassis rigidity. Quote Link to comment
GBean Posted November 13, 2013 Report Share Posted November 13, 2013 If you buy from T3, know you are supporting an outstanding business and a guy who quite literally stands behind his products and does not rush production to just sell stuff. Gabe is very professional and has excellent business acumen.I have a few small T3 parts and LOVE them, especially the swivel bearing top hats.Will be getting the T3 T/C rods shortly. Just wondering and completely off topic (kinda, but IDGAD) What GOOD adjustable shock inserts are still available for the 79-83 ZX struts? I cant find anything easily that is priced right and new... Quote Link to comment
KlassicMotion Posted November 13, 2013 Report Share Posted November 13, 2013 Just wondering and completely off topic (kinda, but IDGAD) What GOOD adjustable shock inserts are still available for the 79-83 ZX struts? I cant find anything easily that is priced right and new... Try KYB AGX. I'm not sure if they have a set for the 280zx... I just bought the AGX MR2 insert for my shortened 280zx struts. THMotorsports had them for $80 each with free shipping!! (Even to Alaska!!) Here: Tokico Illuminas http://thmotorsports.com/tokico/tokico_shocks_illumina_series/tobz3038/i-526639.aspx The pic is incorrect, but I've seen that error a lot. Quote Link to comment
Uber Deaf One Posted November 16, 2013 Report Share Posted November 16, 2013 +1 for KYB AGX Quote Link to comment
Fat510 Posted November 16, 2013 Report Share Posted November 16, 2013 Fronts are 325 I don't remember rears but I think they're 250-300 should i get this spring rate for my car? because my car is like 300-400 lbs heavier Quote Link to comment
q-tip Posted November 17, 2013 Report Share Posted November 17, 2013 It really depends on the ride you want, most say that any thing over #250 in a 510 is too harsh but it really isn't. With your goon the extra weight is in the rear, I would say anything between #250 and #300 would work for the front Quote Link to comment
KlassicMotion Posted November 17, 2013 Report Share Posted November 17, 2013 It's purely a matter of personal opinion. If you order a set of T3 coilovers, you can request whatever springs you want. Lets say you order 200# springs to start with (200# seems to be the average consensus, so probably a good starting point). If you don't like the ride, check out Summit Racing. They have springs you can order for $38 each. You can get softer or firmer springs. Quote Link to comment
Fat510 Posted November 18, 2013 Report Share Posted November 18, 2013 Okay, that makes sense. My car rides like a caddy right now so I don't want to mess that up haha Quote Link to comment
KlassicMotion Posted November 18, 2013 Report Share Posted November 18, 2013 Somebody have a suggestion I like how low hella 510's is but it seems he have to tinker with the kit looking to go sr20 (someday of course) For what it's worth, the SR20DET and 5 or 6 speed will add about 100lbs to the front of your car. Quote Link to comment
Fat510 Posted November 18, 2013 Report Share Posted November 18, 2013 the KA about 10-20 lbs heavier than the SR, right? Quote Link to comment
banzai510(hainz) Posted November 18, 2013 Report Share Posted November 18, 2013 i got 180pounders Quote Link to comment
q-tip Posted November 18, 2013 Report Share Posted November 18, 2013 Okay, that makes sense. My car rides like a caddy right now so I don't want to mess that up haha In that case, I would say less than #250 for a softer ride. Or don't mess with it. Quote Link to comment
Fat510 Posted November 19, 2013 Report Share Posted November 19, 2013 In that case, I would say less than #250 for a softer ride. Or don't mess with it But I want t3 coils man. I could go uber low haha Quote Link to comment
q-tip Posted November 20, 2013 Report Share Posted November 20, 2013 If you want coil overs and a soft ride I would be willing to bet you'll have to buy more than one set of springs Quote Link to comment
Fat510 Posted November 20, 2013 Report Share Posted November 20, 2013 Probably...does T3 do exchanges? Quote Link to comment
KlassicMotion Posted November 20, 2013 Report Share Posted November 20, 2013 Probably...does T3 do exchanges? Start over, what setup do you have now? Quote Link to comment
