DVDSWANs HB Build
  • 4 weeks later...
  • Replies 78
  • 4 weeks later...
thanks guys.
so I've gotten bug eyed from looking at and doing wiring.  so today I finished the doors, installed the rest of the HVAC stuff, and install the brake stuff in the engine compartment.
1939457_10152777659497490_16827226865219
947150_10152777660412490_243634277671813
1920264_10152777660667490_37116706501485
10339550_10152777661192490_6317847081175
post more pics of the stepside in the background!
nothing special, just the next project after this one.  78 Chevy Cheyenne K10, 350, 4 sp, 205, 12 bolt rear, dana 44 front, factory bucket seats with console, dual tanks, and gages.
http://s36.photobucket.com/user/dvdswan/story/10553#add-text
thanks guys.  Ok, i'll give you a bone on the stepside....  as said before its a 78 Cheyenne K10 basically all stock.  only things that have been change (by POs) dual exhaust to single (probably rusted out due to age), engine ( has a target 350 now, 4 bolt main, found out when I changed the pan gasket), rear bumper (must have towed stuff), G80 diff is gone (probably grenaded by POs, or maybe an accident because when I serviced the rear diff it had a j/y making on the diff cover under all the grease), 4" spring lift (no blocks), trailer brake module, and LED taillamps (for a trailer none the less).
when I saw I had to grab it, I was looking for a Blazer or K10 stepside which ever I got a better deal on.  its completely stock, yes, stock pretty much unmolested right down to the factory AM/FM (non stereo, mono speaker) in the dash.
1524820_10152094015092490_1873676259_n.j
 factory buckets (rare in a pickup, everyone wanted the bench to hold 3 people)
1471188_10152325536007490_776933997_n.jp
it even has carpet on the back wall
1526514_10152094014662490_800983527_n.jp
the wood bed is well... its shot, but it will be replaced soon
1513212_10152094014837490_520813716_n.jp
I've done quite a bit to it already, mainly maintenance, but a few new things.  intermittent wipers, brush guard, and a CB.  its still rough on the edges but runs like a champ and gets driven pretty regularly now.  plan for it will be a complete resto with new touches.  adding AC, sound deadening (surprisingly its very quiet now on the freeway), and a few other things.  I'm thinking of a LS engine with a NV5600 trans but at a minimun a 383 with fuel injection and a NV4500 trans.
1966772_10152281895492490_1050328737_n.j
this is the rough side
1471137_10152349725687490_24935108345755
oh, I made a dual intake air cleaner for it
10259913_10152388060957490_1881707087039
I'm trying not to do anything to it as it's the next project.  see how that works...
  • 2 months later...
so I finally touched the truck again.  I started running the battery cables and mounted the battery box in the bed.  I'm still trying to figure out the best way to run the cables to the box.  Not sure if I'm going to use something like this thru the bed floor...
or just run the cables thru the bed floor to the battery.  I'm leaning more to the connection way.  the cables will run to the front where the battery was to these...
where they will be run as if the battery was there.  so what are your guys thoughts on this?
  • 6 months later...
soooo its been a little while since I've posted anything.  Ok a long while.  I have been working on it though, not as much as I'd like to but still.  Its close to being finished... ok at least starting.
finished the hood...
1920526_10153403854427490_78624766392213
11427170_10153403854422490_4692793933678
made the throttle cable bracket and started the air intake system...
11665377_10153460841232490_5043822681935
11402946_10153469150472490_7456820641777
added a 1" body lift for clearance issues with the fuel and trans lines then just about tied up the fuel lines and battery cables to the bed.  I had to order a few more parts and that should be done next weekend.
11694781_10153514011047490_9090922029904
11137182_10153514011002490_5858162513453
16181_10153514010742490_8382609149511632
11755180_10153514011077490_6157359944931
  • 4 weeks later...
