Engine Porn (beyond ... saturation)
It said Blue Flame on it. I don't think it said Six. It was a long time ago. I think it was a decal.
The Corvette probably used the latest upgraded available six in '53/'54, same as the later '57 fuel injection 283. They took an available older engine and souped it up.
https://www.ecklersearlychevy.com/chevy-valve-cover-decal-blue-flame-six-6-cylinder-1949-1952.html
837001.jpginline3.ashx?modified=20170726020718&mw=
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=805417
https://www.rodauthority.com/tech-stories/engine/project-geronimo-evaluating-a-vintage-engine-what-do-we-do-now/
The Engine: A Historical Overview
The first thing we wanted to evaluate in the pursuit of our overall goal of creating a daily driver, was  the vintage truck’s engine. The old “Blue Flame” engine didn’t necessarily need to be rebuilt to specs, but we needed a strong platform to work from. And, by the way, the Blue Flame reference was used by GM in its marketing efforts starting in 1941, because a blue flame in the cylinder meant better combustion than a yellow flame. That scientific marketing research was conducted before the Internet, so you know that it is true.
The 235 Blue Flame was replaced in 1963 with the third generation 230ci Chevrolet inline six, at which time the aging 235 was dropped from production after a 21-year manufacturing run.
'51 Chev
Seems like the Blue Flame has been around a long time. Corvette just made it better.
  • Replies 4.9k
'51 Chev
That 140 is proof you can put a decal on anything, and call it what you want. That is a later model engine, 63 or newer. ?
And I refer you again to the Chevy performance article;
Chevy product planners had a different outlook. They reasoned that if the Corvette came with a manual trans, the public would view the car as old fashioned. After all, went the thinking, who wants to shift gears like they did in the olden days? So, from the beginning, a manual Corvette was not a consideration. Besides, the Powerglide two-speed auto was perfectly matched to what was then known as the Powerglide six-cylinder engine.
The Powerglide six was a solid, passenger-car version of the 235ci Chevy truck engine that had been around since 1929, when it was known as the Stovebolt Six. It made 115 hp using wedge-shaped combustion chambers, hydraulic lifters, 7.5:1 compression, and a single-barrel downdraft Carter carb. The '53 version received aluminum pistons (a first for Chevy), full-pressure lubrication for the bottom end, and steel-backed inserted rod bearings.
3 hours ago, G-Duax said:
More info than I ever cared to know about a chevy 6......
What next, a whole page of pictures of a John Deere B engine ?
What's wrong with a Johnny popper? They were amazing in their day! Our neighbor had 3 of them and you could hear them every time they were out in the field working. Too bad they don't put it under load so you can hear the true sound. The smaller round thing on the other side is the brake.
Edited by goes2fast
I sat on one for many an hour back in the '60s.
The early ones had an exposed flywheel on the left side, with finger groves on the inside for starting.
To start, turn on the fuel, open the two petcocks on the sides of the cylinders (compression releases), grab the big flywheel, give it a good yank with everything you had, and hope it fired.
If it did, close the petcocks real quick, because they were blowing fire at that point, and away you go.
And the smaller round thing on the right is not only the brake, but also the flat belt drive for things like saw mills.
Edited by G-Duax
  • Thanks 1
