sreams Posted September 26, 2013 Report Share Posted September 26, 2013 I've seen this mentioned as an option. With stock roadster springs, how much do they lower a 411 (if any)? Is the stock spring rate different? Are shocks also interchangeable? -Scott 1 Quote Link to comment
erichwaslike Posted September 27, 2013 Report Share Posted September 27, 2013 its the competition springs you want to get, nets about 2 inches lower adn i think is a bit stiffer. Quote Link to comment
MikeRL411 Posted September 27, 2013 Report Share Posted September 27, 2013 For the standard height suspension I have the model and part numbers for Sears lifetime warranty gas loaded shocks, front and back. They provide good correction from stiff sidewall 82% cross section bias ply tires that were 411 standards and modern softer sidewall 80% cross section radial tires. I don't know if a 2 inch drop would compromise the shock absorber action. Erich would most likely have that info. I use 80% cross section radial tires to keep speedometer calibration almost spot on. Quote Link to comment
erichwaslike Posted September 27, 2013 Report Share Posted September 27, 2013 a 2 inch drop would be ok on the shocks. with arm length and shock ratio etc the shock only moves about half of what the wheel does, maybe less. i know stock length shocks will allow you to compress the arm to the crossmemeber up against the bumpstop mount, with no bumpstop installed and dont bottom out.... yes i drove my 411 like this for a few days lol. so there is no need to change out shocks for length, just for ride quality Quote Link to comment
sreams Posted September 28, 2013 Author Report Share Posted September 28, 2013 2 inches might further than I want to go with this car. Would non-competition roadster springs result in maybe a 1 inch drop? -Scott Quote Link to comment
MikeRL411 Posted September 28, 2013 Report Share Posted September 28, 2013 2 inches might further than I want to go with this car. Would non-competition roadster springs result in maybe a 1 inch drop? -Scott Maybe 46 year old coil springs already have a one inch drop? Quote Link to comment
sreams Posted September 28, 2013 Author Report Share Posted September 28, 2013 Maybe 46 year old coil springs already have a one inch drop? Good point. What about lowering the rear to match? Are people using blocks to space the leaf springs? Quote Link to comment
erichwaslike Posted September 30, 2013 Report Share Posted September 30, 2013 yes Quote Link to comment
sreams Posted October 16, 2013 Author Report Share Posted October 16, 2013 Okay... here it is with stock Roadster springs and 1" lowering blocks from Summit: I love it at this height. Looks "right" without looking slammed for my taste. -Scott 2 Quote Link to comment
Swedishcadillac Posted October 16, 2013 Report Share Posted October 16, 2013 Looks great! I'm thinking about getting the competition springs for my 410 wagon. Wondering if anybody would chime in with the optimal shock to use with a 2 inch drop? Going to hit up Just Joel for custom lowering blocks. Thinking ill use air shocks for the back... Quote Link to comment
Swedishcadillac Posted October 16, 2013 Report Share Posted October 16, 2013 Sorry for being a sissy, I looked on KYB shocks specifications page and I will subtract the amount I lower the vehicle from the stock shock height, must think before posting... Quote Link to comment
sreams Posted October 17, 2013 Author Report Share Posted October 17, 2013 Sorry for being a sissy, I looked on KYB shocks specifications page and I will subtract the amount I lower the vehicle from the stock shock height, must think before posting... It's not 1:1. If the compressed height of the spring (and thus the shock) drops by 1", the ride height of the car drops by more than 1". Keep that in mind when choosing a shock. 1 Quote Link to comment
erichwaslike Posted October 17, 2013 Report Share Posted October 17, 2013 Looks great! I'm thinking about getting the competition springs for my 410 wagon. Wondering if anybody would chime in with the optimal shock to use with a 2 inch drop? Going to hit up Just Joel for custom lowering blocks. Thinking ill use air shocks for the back... or you could just go to autozone and but the 2 inch lowering block kit for the $35..... Quote Link to comment
whatwouldjessedo Posted February 26, 2014 Report Share Posted February 26, 2014 I tried using Roadster springs in my 411, but decided they were way too soft. Instead I found a second set of stock 411 coils and cut about 1.5 coils off of them. This gave me the same drop as the roadster springs but a better spring rate. As for shocks, I used KYB Gas-a-Just #KG4513, which are listed for Chevelle, El CAmino, Monte Carlo. These worked pretty well, but I wanted more shock so I switched to Doesch Tech Nitro Slammer shocks and am really happy with the setup. Quote Link to comment
Lunatik Posted February 27, 2014 Report Share Posted February 27, 2014 I tried using Roadster springs in my 411, but decided they were way too soft. Instead I found a second set of stock 411 coils and cut about 1.5 coils off of them. This gave me the same drop as the roadster springs but a better spring rate. As for shocks, I used KYB Gas-a-Just #KG4513, which are listed for Chevelle, El CAmino, Monte Carlo. These worked pretty well, but I wanted more shock so I switched to Doesch Tech Nitro Slammer shocks and am really happy with the setup. Thanks for the information... I was researching the shocks today. Regards, Quote Link to comment
