Hello everyone I am new to Datsun and here
Ed-datsun521
  • Replies 189
  • 2 months later...
Thanks
I've been having problems with the truck getting too hot I think once I get a new radiator it will fix it
I saw when I flushed the system the core was sorta clogged I hope this helps
It only over heats on the hwy any suggestions ?
Usually low speed overheats. Check the lower return hose from the rad. If soft it will collapse from pump suction and restrict flow.
Take the rad out and lay with the inlet/outlet up and fill with CLR to dissolve any calcium deposits.
  • 3 months later...
