HeyJoe!'s 521.
HeyJoe!
  • Replies 79
  • 1 month later...
Quick update.
I finally got the 5 speed in the 521. Speedo is off by 25% on the high side. Seems like I can cruise at about 75/80 mph no problem. So when the speedo says 100, I'm (really) going 75 at a normal sounding (not to loud) RPM.  The dogleg shifting is kinda funky, going from first to second can sometimes be a pain. About 1 out of 10 times I shift from first into fourth instead of second, bushings maybe? Overall the truck is much more freeway ready now, I've been driving it a lot more. Very happy. :thumbup: :thumbup: :thumbup:
I've had this truck for 2 years now and decided it was time to take out the insulation/crap that was glued to the floor when I bought it.  I don't know how long this stuff was in there before I got it, but I'm guessing it was quite a while.  I didn't expect it to look this bad when I pulled it up..... :sick: :sick:   vvv
Drivers side is much worse than passengers side. I used to park it outside before I moved a bunch of stuff around and started parking it in the garage full time. When it rained I would always find a (small) pool of water on the drivers side floor.
I'm planning on pulling the seat out tomorrow and doing a clean up, wire brushing. Then figuring out what the next step is....
Also, I found a couple "snaps" (see pics below), anybody know what the could have been for? They're right by the corner of the seat on both sides, I never saw them till I pulled out the silver stuff.   vvv
Cheers!
Pulled the seat, drain plugs, kick boards (these things can't be that hard to make right?) and package tray. I put in a old drawer and a piece of wood for a seat and drove around the block, it was a scary ride, the drawer kept sliding around, I couldn't tell if the clutch was all the way in or not, I couldn't see out the windows right, I was sitting to low...I won't do that again.  On to the pics from today.......
I think the jack that was in the truck (not a datsun bottle jack) when I bought it caused some of the rust problems.   vvvvv
I was planning on just pulling up the insulation and putting down some por-15, but the drivers side floor was worse than I thought. So it's turned into a little more involved project. I started grinding some of the rust/gunk off the drivers side floor today, it's pretty slow going. I think the PO used some kind of goop before he put down the insulation.
Here's the stuff I bought yesterday, a set of rollers so I can drive my truck while I have my rims powdercoated (someday).  An extra 521 dash top (in case I want to go back to a padded 521dash someday) and a extra tranny hump cover, I guess I'm collecting Datsun parts now...?
  • 1 month later...
Quick update.....
Truck was running hot after start up and then cooling down after about 10 minutes on the road. I replaced the thermostat and radiator hoses.
It's running at normal temperature now.
I drove out to the Valley the other day, no heat issues. It was about 95 degrees.
I bought a set of old blue & yellow license plates from Craigslist....I like the blue and yellow better than the "modern" ones.
Just duck taped on for a pic...
That's a lot of RTV/sealer on that thermostat, you only need a very thin film, you should hardly be able to see it.
Wayne,
That's the goop that was on the thermostat housing when I took it off. I scraped it off. When I put it back together I used a gasket/thermostat/hoses from partsgeek.com, worked out pretty good.  Here's what it looks like now.  vvvvv
