Loren O Posted April 1, 2016 Author Report Share Posted April 1, 2016 We'll I had to warranty the Brand new battery I got the other day. The nee one,I got today seems good ,so far. I poured a little gas in the carb,then put the fuel hose into the gas can (since I need a replacement fuel filler hose.) The truck started right up,when I turned the key. I haven't put the radiator in yet,so I can't let it run for more than a minute. Here's a video of the truck running, AR my job at Wilsonville Nissan. 2 Quote Link to comment
HOGIE Posted April 1, 2016 Report Share Posted April 1, 2016 That would be sweet to hit all 4 shows. 3 Quote Link to comment
Eagle_Adam Posted April 11, 2016 Report Share Posted April 11, 2016 So what's left? 2 Quote Link to comment
Loren O Posted April 15, 2016 Author Report Share Posted April 15, 2016 I'm waiting for some parts at the moment. I also need to replace some of the metal brake lines,get the rear brakes working. I also need to figure out why none of the lights except the front emergency flashers work. I need to put the radiator I have in,so I can let it run longer than a couple minutes. I also want to get the lowering blocks installed, get the torsion bars adjusted. Oh,& I need to get the rust holes patched. 1 Quote Link to comment
flatcat19 Posted April 20, 2016 Report Share Posted April 20, 2016 Get on it. 2 Quote Link to comment
KoHeartsGPA Posted April 21, 2016 Report Share Posted April 21, 2016 Ya...what gato said 2 Quote Link to comment
Loren O Posted April 21, 2016 Author Report Share Posted April 21, 2016 At the moment I am waiting for some parts Al is sending me,& to get the patch panel. I still need to get the bad brake lines done,& get some help sorting out why most of the lights don't work. 1 Quote Link to comment
KoHeartsGPA Posted April 21, 2016 Report Share Posted April 21, 2016 Well....get to bending and flaring...ain't gonna do it on its own... :poke: 3 Quote Link to comment
flatcat19 Posted April 21, 2016 Report Share Posted April 21, 2016 I actually stayed late, after work, to do work on my truck. This did two things... No one was around to fuck with me/distract me... and...i was busy working, so I had less time to cry about what I needed to be doing. 2 Quote Link to comment
Charlie69 Posted April 22, 2016 Report Share Posted April 22, 2016 Brought my truck to my work at Wilsonville Nissan, so I could keep working on it, since my apartments don't allow working on vehicles on the premises. Gonna miss Shawn,his wife Rebecca, & their family, now that they have moved to Arizona. I met Shawn a couple weeks ago at Gene Knight's, good people. I like all the work he has done to his 521. I gave him a 720 dash to work on for the replacement of his dash in his 521. 1 Quote Link to comment
Charlie69 Posted April 24, 2016 Report Share Posted April 24, 2016 Psssst psssst. You should just purchase this off me and not have to worry about cleaning that cover Wow that NAPA Aluminum Brightener really works!!! LOL 1 Quote Link to comment
Loren O Posted April 26, 2016 Author Report Share Posted April 26, 2016 I wish my valve cover looked like that. I cleaned it up, what was left of someone's black paint off of it,but I haven't made time to polish it yet. 1 Quote Link to comment
KoHeartsGPA Posted April 26, 2016 Report Share Posted April 26, 2016 Get those lines bent and flared yet???? 2 Quote Link to comment
Loren O Posted April 26, 2016 Author Report Share Posted April 26, 2016 Not yet,no. I gotta get some brake line tubing first. The front brakes are semi functional,so the truck can be moved around, if necessary. Hopefully I will have time to work on it today on my lunch break. I need to replace the fuel filler neck hose also. It has a split,so I haven't been able to get gas into the tank. We started it off a hose,running into a gas can. 2 Quote Link to comment
DanielC Posted April 26, 2016 Report Share Posted April 26, 2016 Loren, I hope you are not upset, I am going to put this here. My 521 is finally nearing drivable status. The engine is in, we have started it,etc. Once I installed the battery ,had it where it would run,I found that only my front emergency flashers work, no other lights whatsoever. The heater fan,& wipers work though. It has power to the fuse box,,and power on both sides of the fuses. Being that you're the resident electrical genius, especially with 521's, I thought I would ask for your help. Here is two wiring diagrams for 521 trucks. first one is the truck, but for a 1970, manual choke truck, 1972 521 had an electric choke. This is a lights only wiring diagram. The standard 521 first thing to check, when having electrical problems. Check for power on the fuses, on the side away from the battery. Do this with the lights or whatever on. If you use a decent electronic volt meter, a slightly damp bad connection will pass enough voltage to make a volt meter read 12 volts, but will not carry any current. Before I put tail lights, side marker lights on a project truck I bench test then first. When you know the tail lights are good, then you can look for wiring problems. If the tail lights are not good, you do not know where to start. Ok, you tested the tail lights, and they work. On a 521 the next thing I would check is the tail light ground. The tail light harness connects to the tail light frame. The tail light frame should ground to bed sheet metal, and bed sheet metal should ground to the trucks frame, and the trucks frame should ground to the engine. If you connect a long wire to the tail light frame, and run that wire up by the battery, check the voltage between that wire, and battery negative. It should be less than .2 (two tenths of a volt) The front park lights, the heater, and the wipers all ground to cab sheet metal. If the ground is bad for the rear lights, the front electrical stuff would still work. There are two wiring harness plugs by the starter. Look for the six pin plug. It may have bad connections. Unplugging, and plugging it back in may fix a bad contact issue. That should give you some things to check on. 2 Quote Link to comment
Loren O Posted April 27, 2016 Author Report Share Posted April 27, 2016 Thank you, Daniel! I will check those things out. 1 Quote Link to comment
Loren O Posted April 27, 2016 Author Report Share Posted April 27, 2016 Had to move it around some,so I took a couple pictures while I was at it. 2 Quote Link to comment
flatcat19 Posted April 27, 2016 Report Share Posted April 27, 2016 Needs more lower. And to be fixed. Hurry the fuck up! 3 Quote Link to comment
thisismatt Posted April 27, 2016 Report Share Posted April 27, 2016 Needs more lower. And to be fixed. Hurry the fuck up! Says this guy ^^^ 2 Quote Link to comment
flatcat19 Posted April 27, 2016 Report Share Posted April 27, 2016 Says this guy ^^^ I speak from experience. 3 Quote Link to comment
Loren O Posted April 27, 2016 Author Report Share Posted April 27, 2016 I'm stuck waiting until payday, so I can get brake tubing, etc,& a filler neck hose. I am waiting for some other parts to get to me. Lowering will definitely be happening after the brakes & lights work. I already have 2" lowering blocks, & if that doesn't lower it enough, I also have 720 4x4 leaf springs, & new bushings. The front will just be a matter of adjusting the torsion bars. 1 Quote Link to comment
Royal Sierra Posted April 28, 2016 Report Share Posted April 28, 2016 And if you wanna sell those 720 leafs feel free to give me a call... We'll see whos drives first. 2 Quote Link to comment
flatcat19 Posted April 28, 2016 Report Share Posted April 28, 2016 Mine. Tonight. Lulz. 1 Quote Link to comment
Royal Sierra Posted April 28, 2016 Report Share Posted April 28, 2016 Not if i can help it 1 Quote Link to comment
flatcat19 Posted April 28, 2016 Report Share Posted April 28, 2016 Off work in an hour and 10 minutes. Running in half an hour after that. 1 Quote Link to comment
