Bagged and BD 67 V520
finney
  • Replies 285
Saturday is for UPDATES
Cut some steel out of the 520 and welded it into the V520. Came up good!
11427216_10153354337399764_6209919190240
11406941_10153354337479764_4261027622561
11400971_10153354337754764_7620404164286
11391538_10153354337914764_4887606245943
1554441_10153354407604764_58968269273981
11351249_10153354407764764_7882499735316
11224823_10153354407674764_1198306812734
Next up is making a brake booster from a 80s Toyota pickup fit (Because I have one). Some of you may have noticed the driver side tub is not welded to the firewall, I will fabricate space for the booster.
  • Like 4
yeh I plan on rigging up a latch of some kind, will not be too hard. The lines looked better with the flap installed that way round.
It was nice to get it off the Ibeams and see it another 100mm lower.
Thanks for the comments.
  • 4 weeks later...
Today was spent tackling some rust spots. There was a little more than expected when I pulled the windscreen out. Luckily I have some spare steel to help.
Drivers side - behind the dash, rather ugly
11742786_10153442998789764_3003388455457
11665603_10153442998824764_3108997648889
The replacement sheet metal off the 520 looks like it just ran off the line
11745375_10153442998634764_5553851393664
Replaced the whole area thats bare metal
11230582_10153442998474764_3304771769543
Passenger Side - Again a fair amount of rust behind the dash area. There was a fair amount of work to get the trimmed rust repairs to match up, as it meant matching both the inside and outside skins
11737810_10153442998734764_4153501607201
11262139_10153442998574764_6106286200169
11698563_10153442998539764_3689177510554
Passenger side is 75% welded in.
  • Like 4
Everyone loves a Monday off work, when the wife is at work and the little one is at the grandparents house!!!
Today I finished the rust repairs on the windscreen and replaced the lower sections of both guards.
A good reason not to use masking tape to mark out your cut lines FAIL
11742741_10153447192704764_7073362605132
Windscreen finished, but some rust around the wiper cowl ready to be replaced
11750645_10153447192674764_7793042535652
Some hidden rust, that was also repaired
11752461_10153447192729764_2028157489876
Lower guard
11745752_10153447192759764_4892095786708
11745421_10153447192594764_8399172908460
  • Like 5
Thanks guys,
The billets have been floating around the workshop since i bought them 6 years ago, they need to be re polished as they are covered in shit. The wheels have been a curse for a couple of projects now.
I am really confused at the moment with getting the body mounted correctly. I am 15-20mm lower on the passenger side, but i can't figure out why. THe passenger side is to the measurements I originally calculated. Everything has been squared, braced and jigged up when welding and all the panels line up. I can't find anything holding up the drivers side. Its going to be something small but its one of those thing where you adjust one mount and it changes everything and it is time consuming with  no gain. I am using new nylon body mounts I had machined up, as appose to the old rubber mounts used previously. The chassis is slightly different side to side from factory, but not that much!! Fucking annoying
Next weekend I plan on finishing behind the guards and move onto the doors. The doors on the truck are in great condition, so they will be transferred across, with only a couple of minor repairs needed.
The lower rear quarters are rusted out fairly badly. I am hoping I will be able to match some of the compound curves with some sheet metal off the roof of the truck. fingers crossed.
funnily enough I am not being as anal as I have been in the past on this build, I actually want to finish this one within 6 years :) Its been almost 2 years worth of Saturdays now.  Still a few more to go.
Looks like Facebook have changed something again and all the photos have disappeared again.
  • Like 3
Now I am happy mate she looks like a cunt..lol sorry I know you guys use that word a lot..I had to say it..sorry
:) A horrible word and not quiet the "right" context
Mate, now I am happy, thats looking sic cunt
:rofl:  :rofl:  :rofl:  :rofl:
10505614_10153480654259764_7069058274325
11800050_10153480654154764_6837134685871
It kills me a little that its not laying body, especially with going to all the effort of a 3" body drop, however no chassis are permitted in the state I live in, previous rides have been notched, but i don't want this to be in line for a scrap heap if I am pulled over and inspected by the Five 0. Still not a bad effort for no notch and 19" billets.
  • Like 3
I hear you on falling short of laying body. I did a C-notch, custom lengthened LCA's, driveline tunnel, exhaust tunnel, yada yada yada. I lay front subframe, arms and rear leafspring hangers, but rockers are 1.5 to 2" off ground... It is still awesome tho. The only way to really lay body in these unibody rigs seems to be full floor removal and custom frame... Which seems to me to lead to way more time & $$$. I'm stoked to see you have the ability to go there but have decided to keep your project managable. Finished, drivable and brutally low are awesome goals. Love seeing the progress!
  • Like 3
