Bagged and BD 67 V520
finney
  • 1 month later...
  • Replies 285
After working on the old girl flat out during January, I have been a little burnt out and surfing rather than touching the 520. Last weekend i spent a couple of hours pulling the engine out. Today i spent 1/2 a day buzzing off surface rust, sanding the body and putting some etch primer down.
12809673_10153969020129764_2765466298077
12832428_10153969020064764_9162025392722
  • Like 7
  • 2 months later...
It has been way too long since an update of anything substantial, this update is probably is no different. I have been sanding down the body and modifying/rebuilding the wiring harness, not much to show, but still progress.
A photo from this evening for good measure.
13166126_10154182386329764_6923078152425
  • Like 5
  • 3 weeks later...
I am not planning on taking the whole car back to bare metal when i repaint, however the guards were in really bad shape. I will also be taking my doors back, as i am using my old 520 doors that are covered in "rust" Paint
13327629_10154223666804764_2160720101878
13331012_10154223666799764_2174569731151
  • Like 3
I have noticed that most of my links to my build photos are broken. I have started a Instagram build @datsun_v520 if anyone would like to see catch up on my old photos.
As of this afternoon both doors are now striped inside and out. I need to finish off the nooks on the passenger front guard. Next on the to do list is strip the tailgate and the bonnet. The Bonet sat on the front end for the first time in over 2 years, I will need to find a manifold and SU to keep the bonnet from going under the knife.
No idea what paint went on the bonnet, i have given it 2 coats of paint stripper and it has barely touched the paint.
13427812_10154271618944764_2464476629780
13423759_10154271618179764_2971783854887
  • Like 6
  • 2 months later...
This Sunday started with jacking up the rear end, whipping off the Intros and stone guarding the rear wheel tubs. The day finished with trying on the other set of shoes that I scored off a mate for a couple of cartons of beer. Brand new steelies and what I believe are some old Ford hubcaps. The Hubcaps are amazing, the rims are going to get a fresh powder coat in an undecided colour.
14370226_10154543209034764_6270083984727
14355715_10154543209169764_5910500322273
  • Like 5
  • 1 month later...
Well it looks like all the links off Facebook have changed again. If you would like to see any of the older posts check out my Instagram Datsun_V520
A few updates, The rear upper tailgate was totally fucked, rusted almost beyond repair. I had to pass it onto a hot rodding mate to help fabricated the lower sections, due to the complex curves, I did not get any before shots, but trust me the bare steel section is completely new. I got it back and replaced the lower corners.
15170839_10154753995739764_6498728192232
15193613_10154753995699764_654141717784415107361_10154753995594764_2772046081955
15202594_10154753995609764_8641107179834
Started to bolt the doors and the guards back on for the first time since I cut the floor out for the body drop, did the front tubs and put on the 520 single headlight rad support. Gaps are looking fairly good with minimal tweaking thus far.
Doors were originally from my 520 truck, door sills off the 520 truck, 1/2 lower front guards are both from the truck and every panel has had a fair amount of welding, so there is a bit to tweak.  probably start swearing, cutting and welding once i start trying to get them spot on.
15094476_10154753995354764_5312927730008
 15135952_10154753995349764_1035902563977
  • Like 4
Stock steering shortened approx 3", seat moved back 4", seat lowered 3" and a little trimming to the brake/clutch/steering mount. Looks like my lanky 6'5 ass might actually fit back in this little Datto
Bonus points for the badass stock steering wheel still fitting
15078793_10154753995484764_3525353300424
15170949_10154753995534764_7836912693597
  • 3 weeks later...
Following on instagram @datsun_v520 you may have already seen these
Decided to start lifting the wheel arches 50mm, will allow me to drive 50 mm lower on my 19s. Win Win
Marking out the first cuts
15390786_10154817641934764_4521284416349
Decided masking tape gave me clean lines
15349702_10154817641919764_6872425474790
mock up
15355666_10154817641894764_6864588175219
Bought a new 9'6' that will look bad ass on the roof once this is one day finished
15390918_10154817641794764_4052393315108
Started tacking this arvo in a spare hour, then got stuck into my 7.5% West Coast US IPA, that I have also been working on for a fair while... The day job....
15400909_10154817641769764_3850669778902
15380572_10154817641754764_6724324711800
Time to burn the rest in...
Ride hight on 19s
15319235_10154817641864764_6874712177210
  • Like 7
