Lockleaf Posted March 27, 2016 Report Share Posted March 27, 2016 Apparently I can't tell my right from my left.... Thanks for the correction Mike. 1 Quote Link to comment
datzenmike Posted March 27, 2016 Report Share Posted March 27, 2016 It happens.... 3 Quote Link to comment
RatVonDude Posted March 27, 2016 Report Share Posted March 27, 2016 think I found it up underneath the passenger side back wheel well, about 8" off the pump. It looks like the style fuel filter that has nipples horizontal/running through unlike the one they sold me which is white, with nipples parellel ( all jokes aside ) It bolts to the rear frame of truck right? I hope this is the problem, the filter looks ancient. 1 Quote Link to comment
Lockleaf Posted March 28, 2016 Report Share Posted March 28, 2016 It slips in to a small round bracket stock. What you have with two nipples on top is the correct filter. What is on your truck is not the correct filter. It shouldn't be bolted in to anything. 2 Quote Link to comment
RatVonDude Posted April 1, 2016 Report Share Posted April 1, 2016 turns out it was the hitachi carb all along. Thing is running excellent now. 1 Quote Link to comment
weldingrod Posted May 26, 2018 Report Share Posted May 26, 2018 If you think getting the relay out is hard, wait till you try to put it back in!! Tried all the tests I read about, no joy with fuel pump. Jumped with battery, pump runs. Remove relay from parts truck, do something else for a week, forget to see if pump operates with parts relay, work on sauna for a week waiting for new relay, install, everything works fine. I just don't understand when I installed a jumper at the appropriate contact on relay connector why pump did not work. 1 Quote Link to comment
Charlie69 Posted May 26, 2018 Report Share Posted May 26, 2018 Here is the Nissan Factory Parts Manual drawing noted of the stock fuel filter that is between the tank and the fuel pump.. You should always have a filter before the fuel pump. Stock 720 fuel piping for electric fuel pump. Stock 720 electric fuel pump on the drivers side of my 1980 720 chassis under my 66 520. Quote Link to comment
