Walli's Dirti Martini
Phixius
Stupid Karma!  Heres the broke stud I had after making fun on jrock...
drilled a hole in the stud and it went in a little further, then tapped in a bit.
its working..
yay! its out.
Got a question on the 5spd swap tho...  72.5/73 came with short tail 4spd and 74+ came with long tail 4 spd or 5spd.  searching its seems that you can use the same crossmember with 5spd mount.  But, all the info I see is for the 74+.  are the crossmembers the same for all or are they different and if so will it bolt up or do I need to custom fab a crossmember?  I have no problem making one, just be nice if we can spend a couple bucks for less work/time...
Oh, and I popped off the oil pan of the l16 that came with the truck...  Time to play, WHATS IN THAT OIL PAN!?!!???!??
wtf, Is ths normal?   :frantics:   haha!     this was after I squirted that shit with what was left of my cleaner on the sludge, didnt even notice what the chunks were when scraping them up from the bottom...
 lots of shit in there, broken bolts, unbroken bolts, LOTS of metal pieces, a shaft key, and much much more.  this motor is just Fucked...  who wants it?
  • Replies 117
  • 1 year later...
  • 1 month later...
  • 1 month later...
