Kitchs 1971 Datsun 1200 Coupe Project
  • Replies 114
  • 2 months later...
Did you have to do much modification to get the Z seats to fit?
I actually have just solid mounted them at this stage, but plan to remake the Z seat frames/rails to have different tabs welded to them to pick up on the 1200 mount points, so they will be able to slide.
I have just used some 40x40x3 angles spanning across the 1200 mount points, and then drilled holes through top to suit the Z M8 fixing holes, and packed seats off these angles with some short spacer tubes
