Super low IRS wagon build
  • Replies 116
I probably won't make it this month. I have a customer car on the lift and I still haven't done the exhaust on the wagon. Its much too fumy in the car to drive long distances because the exhaust is straight from the manifold right now. Ill try and post some more pictures soon, I'm running 6" stroke Bilstien small body circle track shocks in the rear. I bent a new fuel line that runs safely through the drive shaft tunnel. I also ordered a supercharger and will be setting that all up in a couple months. I have all my exhaust parts (tube, bends, hangers, etc.)  but haven't chosen a muffler yet. Any suggestions? I am thinking of running a dynomax ultra flow welded muffler. The whole system will be 2.5" and will include a new header that i will build to accompany my new intake manifold for the supercharger.
  • 2 months later...
Well, it has been a while. I have been working on a ton of things, and school has taken the majority of my time. I thought I would post some of my latest progressions. These are not done yet, they will get a sheetmetal piece at the bottom that will tighten up the hole the shocks pass through, and I am making some 50 shore urethane gaskets to seal the opening in which they pivot.
1797612_10152207174958071_13297688304817
1544422_10152207175053071_57300655048938
1484241_10152207175068071_67378161708122
not quite finished yet...
  • Like 5
  • 1 month later...
Just finished a customer project that has been holding me up, so I will be getting the wagon all finished up for myself. Current progress puts me at cars & coffee in Irvine on July 12th. If anyone is going, please stop by, check things out, and say hi! Should have the shocks all done and the exhaust run by then.
10411984_10152343118988071_2306509239631
Shocks done, Just a little shrouding and some urethane gaskets and the whole setup is finished
10448799_10152343118998071_6116489881099
10527414_10152343119063071_3152886539372
10419473_10152343119113071_5697429821496
Tackled the exhaust yesterday! Cut the down pipe, tucked it closer to the transmission, and opened the end up to match 2.5".
10401513_10152343119093071_1746388925358
10388591_10152343119163071_3354867178202
10524658_10152343119288071_5547485252343
10491258_10152343119348071_2626208246329
No muffler, hasn't come in the mail. So in the meantime I ran a straight section to the bumper. When the muffler comes, I will do the tailpipe section, from the crossmember flange back, in stainless.
10516757_10152343119378071_4338274005423
10509624_10152343119418071_5396292863572
10404185_10152343119518071_4720873905603
10462963_10152343119448071_8600601486981
Forgive the picture dump, I'm quite proud of how nice the exhaust routing turned out. Everything is tucked up very tight and I haven't had any issues with scraping beyond coming into and out of my driveway. Only part that hangs down is the flange at the downpipe, and that is only about a half inch or so below the scrubline.
10484523_10152343118993071_4906866977892
Hope to see some of you Saturday morning in Irvine! If you are there and see the car, come by and say hi!
  • Like 4
I had some flex joints, but due to the car being so low, I couldn't find anywhere to put it that wouldn't either push the exhaust into a ground pounding area or push the exhaust up against the floor boards. Time will tell... The flanges at the manifold/downpipe are thicker than the others also. I drove it to my university today, and its way too loud to keep driving it this way. I just rush shipped my muffler from amazon, so hopefully I can get the tailpipe section quickly setup with the muffler before Friday. Otherwise, she rides great! Conquered the shitty socal freeways and made about 60 miles worth of driving so far.
Only issue I have been having is fuel pukes out my vent filter a bit, so Thursday I need to mount the vent higher above the top level of the tank. I think when fuel sloshes around with driving, it forces fuel up the vent tube. Hopefully an easy fix.
  • 1 month later...
I was finishing up the shrouding around the shocks the other day and carelessly plasma cut my hand, so in the days letting my 2nd degree burn heal to prevent infection, I'm trying to figure out some final details. Any ideas on how to alternatively light the license plate? I'm removing and shaving the stock lights and would like to do something that isn't noticeable. I thought about machining a frame that could house so LEDs but maybe someone has a better idea?
