Super low IRS wagon build
  • Replies 116
I find this thread insanely motivating and so discouraging all in the same... you have skills man.
I can likely build a fiberglass 510 with 3 pieces of bubble gum and a gallon of resin, but metal is my kryptonite. I am embracing the challenge and moving forward.
Thx for sharing your work!!!
Not much to update today, smacked my head on my lift really hard at a brisk walking pace so it put me on my ass pretty good. Finishing up the gas tank situation. Im using a 65 mustang tank that I have removed the filler neck from, and will be putting a new filler neck in the side of the tank so my fuel filler will be in the rear corner of the cargo compartment. I'm using the stock Datsun wagon cap and neck in the floor.
996531_10151626021098071_1909172535_n.jp
I also finished half of the tank mounts today before smashing my skull, ahaha
1075707_10151626020718071_870229293_n.jp
1003716_10151626020883071_1242046843_n.j
also, I played with the exhaust placement a little for what ill be tackling next week.
969020_10151626020938071_1940735173_n.jp
also, for creppy, cause there won't be a thread about it, a couple pictures of the hearse
552228_10151122452183071_2143752884_n.jp
I already camaro clipped the hearse, put a new two link setup on the rear, and swapped a small block into it.
Lets go shooting.I live right around the corner from prado and rahauggues,i cant spell it.
I have never heard of that place but it looks cool. Been dying to go shooting, but I just haven't had the time. You are way close to where I am though. Definitely will have to look out for you at some local meets.
  • 3 weeks later...
ok, so it has been a while. Been working to much so I'm barely getting down to the nitty gritty now.
Small update:
Gas tank conversion is completely finished now. Here is a pic of the frame that supports the tank nearly finished. All the open tube ends have been capped since then to finish it off, and the tank was spot welded to the frame.
The little dip in the frame was for the new filler neck, hole is cut and filed here
1098410_10151667280888071_264166913_n.jp
Filler neck welded in, "beaded," and leak tested
1149040_10151667280673071_1489874589_n.j
Rear tank mounts knocked out
Fuel filler and cap relocated to rear floor, not a bad look I must say
1185521_10151667280973071_1335703057_n.j
1170697_10151667281008071_1383346906_n.j
Then it was time to finish the spring perch. These photos are before it was completed. After welding was finished, a tubular brace was added across the top, between the gussets, to prevent it from deflecting
1173644_10151667280738071_738170068_n.jp
Lower spring clamp fabbed and bolted into place. Forgive some of my welds. I have been having issues with the wire sticking in the liner and feeding inconsistently. Must be dirty or something. Gotta make a trip to the weld supply house next bottle fill to pick up a new one.
The bolts are long because, if need be, a spacer can be placed between the top perch and the spring to lift the rear of the car for heavy loading. This, combined with similar spacers for the shocks (which I should have figured out and underway tomorrow) will allow you to prepare the car for heavy loads. Just keeping the option available.
I'm currently fitting the factory sedan emergency brake linkage today. Should work without issue.
Also, here is a detail shot of the spring to spindle interface. You can see how nicely everything fits with one another. I still need to finish the shackle plates by shaping them a little on the ends so they have a bit more clearance. They don't interfere now, but I would like a bit more space around the ends.
1000344_10151667280558071_804139366_n.jp
<iframe src="https://www.facebook.com/video/embed?video_id=10151662960153071" width="568" height="320" frameborder="0"></iframe>
Here is a video I took a couple days ago. Really advanced suspension test! ;) Mind you, no shocks yet, but when I jump on it, I cannot get it to bottom the travel out. It should ride pretty well once I get some properly valved shocks on it.
I am in dire need of half shaft and driveshaft bolts and nuts. Anyone have a spare set to sell? Anyone have a lead on where to get some. My local bolt supply house that generally has eveything says they don't even know where to start to look...
  McMaster Carr catalog or web site.
