Alleycatgarage So Cal shop
  • Please log in to reply
286 replies to this topic
#281 hosestop@msn.com
hosestop@msn.com
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,429 posts
  • Cars:510 blk 4drsr,65fairlady510 wag24de521na,56delivy56 Ford truck,
Posted 09 January 2018 - 09:25 AM
The color has a slight teal in person color sanded bed rust stained slightly ,may clear or paint bed only.ngSlyey.jpgkE74lHQ.jpgnRbQEr8.jpg
#282 hosestop@msn.com
hosestop@msn.com
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,429 posts
Posted 09 January 2018 - 09:32 AM
Camper had some dry rot bolts in floor busted out, thing was heavy and tall had fridge and two burner, gave it to estate sale buddy that called me . .oLFIhh6.jpg
#283 hosestop@msn.com
hosestop@msn.com
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,429 posts
Posted 12 January 2018 - 05:19 PM
Please give some feedback on this mod + - 1974 Datsun 620 SR20DE NA swap .Removable tunnel for SR20De swap. ( Transmission gets caught under car with frame on 620 and 521 on SR swaps ,may have to pull motor for clutch job ,instead pull seat and tunnel ) installed in car ,Slightly taller , now shift boot lines up with hole and tunnel sealed and screwed down with stainless screws . can't get new shift boot over SR20 shifter damper thing may soak in hot water and lube , shifter fits better backwards in small cab . Built throttle cable with air line hose ,re-use 521 hardware drilled out old housing and use stock cable ends , gets clamped at firewall . Air pipe between throttle body and MAF measures 24" smooth bends shorter than stock one , last one ran smooth like this.OBquFhJ.jpgOCc9xBH.jpg5Y7EhiV.jpgMF0ZGVJ.jpg
#284 mklotz70
mklotz70
    Beelzebub
  • Senior Member
  • PipPipPipPipPip
  • 7,625 posts
  • Cars:'64 Fairlane wgn, '14 Kia Forte EX, '70 521(wife's), '72 521(mine)
Posted 13 January 2018 - 03:07 AM
I'm glad to see that you got the tailgate with the blue one.
Don't have to be too bright to be me!! :D
Sadly, I prove this nearly everyday!!! :(
www.bluehandsinc.com
youtube.com/bluehandsvideo
#285 hosestop@msn.com
hosestop@msn.com
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,429 posts
Posted 13 January 2018 - 08:31 AM
I can't do too much to blue 521 , bummed , stashed in back row of dead players , green 521 inside shop needs 6-8 hrs to get S13na running and as we all know must do customer cars first to get paid. Hey I am selling extended bumper.HnEK5d3.jpgyAD8rsa.jpg
#286 hosestop@msn.com
hosestop@msn.com
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,429 posts
Posted 15 January 2018 - 04:08 PM
#287 hosestop@msn.com
hosestop@msn.com
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,429 posts
