KiloTango1200 Posted June 22, 2016 Author Report Share Posted June 22, 2016 Good work the pans look good. Mine on the other hand look like they sailed the Atlantic and sunk at sea. With the por15......do you apply it on bare metal? Does go on as a spray? Roller? Brush? It's all been brushed on. And applied to POR15 prepped metal. Quote Link to comment
KiloTango1200 Posted June 22, 2016 Author Report Share Posted June 22, 2016 Finally got the nasty engine bay frame rails prepped and coated with POR 15 and Top Coat. Ready to re install the wiring harness and drive it. 3 Quote Link to comment
KiloTango1200 Posted July 14, 2016 Author Report Share Posted July 14, 2016 The left rear quadrant where the left rear spring shackle attaches. Lots of hours stripping the hard to reach areas in the back half of the car. About to remove the differential bump stop to clean and prep the upper part of the rear floor pan. 1 Quote Link to comment
]2eDeYe Posted July 14, 2016 Report Share Posted July 14, 2016 That's a lot of laying on the ground, my arms hurt just thinking about it. :) 4 Quote Link to comment
hobospyder Posted July 15, 2016 Report Share Posted July 15, 2016 but he will have the satisfaction knowing it's done when he's finished and at least have my respect (however little that is worth) for having done it 4 Quote Link to comment
]2eDeYe Posted July 15, 2016 Report Share Posted July 15, 2016 I get that, just sympathizing with the effort. :) 1 Quote Link to comment
dimlight65 Posted July 16, 2016 Report Share Posted July 16, 2016 Unfortunately one of the exhaust manifold studs was compromised and broke off with very little pressure. What are you doing about the busted stud? I may or may not have a spare ceramic coated 4-2-1 A-series manifold at the shop. We'll need to check with John to see if it is actually a spare though. 2 Quote Link to comment
datsunfreak Posted July 16, 2016 Report Share Posted July 16, 2016 What are you doing about the busted stud? I may or may not have a spare ceramic coated 4-2-1 A-series manifold at the shop. We'll need to check with John to see if it is actually a spare though. Option the second, weld a nut onto the broken stud. Usually the heat from doing that will make it break loose and unscrew from the manifold. 2 Quote Link to comment
KiloTango1200 Posted July 20, 2016 Author Report Share Posted July 20, 2016 What are you doing about the busted stud? I may or may not have a spare ceramic coated 4-2-1 A-series manifold at the shop. We'll need to check with John to see if it is actually a spare though. If it is a spare, I would be interested. Quote Link to comment
KiloTango1200 Posted July 24, 2016 Author Report Share Posted July 24, 2016 Checked out the front side marker lights and the reflector and bulb sockets were toast. Ebay had aftermarket side marker lights from Thailand listed for the 1200 but I could tell they weren't even close to being the right size. I only need the reflector/bulb assembly and will be able to make it work with the original lens assembly. Less than 20 bucks including shipping. Not much to loose. The new reflectors are a little too long and a little too narrow but I can make them work. A little work with a nibbling tool and the lenght is perfect. The new reflector in the original rubber mounting. Not correct, but fixable. Quote Link to comment
njoz1200ute Posted July 24, 2016 Report Share Posted July 24, 2016 I know why. Those sidelights you bought are for the ute model..i.e. B120. But kudos for making them work 1 Quote Link to comment
KiloTango1200 Posted July 24, 2016 Author Report Share Posted July 24, 2016 Removed the left rear shock to see if I could remove the rust inside the shock tower. This will be the most difficult job to date. 1 Quote Link to comment
KiloTango1200 Posted July 24, 2016 Author Report Share Posted July 24, 2016 I know why. Those sidelights you bought are for the ute model..i.e. B120. But kudos for making them work I can seal the gaps from the back side of the assembly to make them waterproof. Then spray on the POR 15 undercoat to finish off the job. Quote Link to comment
datsunfreak Posted August 3, 2016 Report Share Posted August 3, 2016 You know those bolt straight on as is, right? ^_^ Quote Link to comment
KiloTango1200 Posted August 4, 2016 Author Report Share Posted August 4, 2016 You know those bolt straight on as is, right? ^_^ You know those bolt straight on as is, right? ^_^ Yes, but I would like to keep the original lenses as they are in very good shape. The reflectors and electrical parts are toast.. 1 Quote Link to comment
datsunfreak Posted August 6, 2016 Report Share Posted August 6, 2016 Yes, but I would like to keep the original lenses as they are in very good shape. The reflectors and electrical parts are toast.. I get that. I just don't fancy them because they are so big and bulky. And not enough chrome on them. ^_^ 1 Quote Link to comment
KiloTango1200 Posted September 15, 2016 Author Report Share Posted September 15, 2016 My Mother passed away on Aug. 28 2016. My family and friends have been a huge support during this difficult time. I now have the time to complete my Ratsun project. Quote Link to comment
Tikka Posted September 15, 2016 Report Share Posted September 15, 2016 All the best to you and yours. 1 Quote Link to comment
Tikka Posted September 15, 2016 Report Share Posted September 15, 2016 If you aren't going to use them I will gladly buy the wiper arms (Here come the vultures). Quote Link to comment
datsunfreak Posted November 16, 2016 Report Share Posted November 16, 2016 Any updates on the car KT? :thumbup: Quote Link to comment
