KlassicMotion Posted June 21, 2013 Report Share Posted June 21, 2013 I pulled my gauge cluster out to clean and install a factory tach. When I did so, this [thing] dropped down. It's a plastic barrel that's 1" long x 7/8" diameter. Can anyone identify this, and tell me where it goes? Thanks. Quote Link to comment
tr8er Posted June 21, 2013 Report Share Posted June 21, 2013 looks like the tube that connects the outer and inner drain tube. It connects the area under the wipers, through your firewall, out the side behind your tire. if I'm right your car must leak like a sieve in the rain. Look up under your steering wheel toward the side wall. If you see a rubber tube, this should fit right into the end. Quote Link to comment
tr8er Posted June 21, 2013 Report Share Posted June 21, 2013 Wait, is that metal? If that is metal I believe that may be a spacer on the pivot armature for your pedal assembly. Check to see if any pedals slide sidewards. Quote Link to comment
Just Joel Posted June 21, 2013 Report Share Posted June 21, 2013 It's a plastic barrel Later Joel Quote Link to comment
KlassicMotion Posted June 24, 2013 Author Report Share Posted June 24, 2013 Anybody? Quote Link to comment
datzenmike Posted June 24, 2013 Report Share Posted June 24, 2013 The 620 has similar ones of those each for directing the turn signal light forward through the green arrow. It keeps the flash from bleeding out to the sides and other gauges. 1 Quote Link to comment
KlassicMotion Posted June 24, 2013 Author Report Share Posted June 24, 2013 Cool. I will look into that. Thanks. Quote Link to comment
KlassicMotion Posted July 10, 2013 Author Report Share Posted July 10, 2013 Not it, that I can tell. Any other suggestions? Quote Link to comment
KlassicMotion Posted October 1, 2013 Author Report Share Posted October 1, 2013 bump. I still haven't figured out what this is... Quote Link to comment
