Royal Sierra Posted June 6, 2016 Author Report Share Posted June 6, 2016 Sitting here getting lunch and watching all the people stare at it as they walk by lol 2 Quote Link to comment
Royal Sierra Posted June 19, 2016 Author Report Share Posted June 19, 2016 So on the way to Canby my engine siezed. Guessing it really didnt like the 4:88 gears. It was a lovely saturday sitting on 99e with my bro (whos KA24de 210 is almost finished) drinking growlers waving at fellow datsuners passing by. Thanks to the guy in the blue 1200 who turned around to see if we were all good. Had truck towed home..i have a line on an L engine and a couple of hardbodys i may pull the gears out of. Truck otherwise functioned well. 2 Quote Link to comment
wayno Posted June 20, 2016 Report Share Posted June 20, 2016 That's to bad, I didn't see you, I would have stopped if I had. :( Maybe Blue Lake? :) 1 Quote Link to comment
Rhino13 Posted June 20, 2016 Report Share Posted June 20, 2016 Damn that sucks man! At least you had growlers to keep you company! Haha 1 Quote Link to comment
Royal Sierra Posted June 20, 2016 Author Report Share Posted June 20, 2016 Im gonna try for blue lake. Depends on my moving situation and all that. I saw your truck there wayno. Lookin good. The fucked part is if I hadnt gone to pick up my buddy in oregon city i wouldve made it to canby so i cna blame it on him lol 2 Quote Link to comment
izzo Posted June 20, 2016 Report Share Posted June 20, 2016 Someone told me you had the engine redone.... I didn't think you did, just had the wiring sorted out.... 1 Quote Link to comment
pl521sss Posted June 20, 2016 Report Share Posted June 20, 2016 I was digging the camper on this truck. 1 Quote Link to comment
datson4life Posted June 20, 2016 Report Share Posted June 20, 2016 I was digging the camper on this truck. Mine is for sale lol i know u were asking me about that engine too 1 Quote Link to comment
Royal Sierra Posted June 21, 2016 Author Report Share Posted June 21, 2016 We just regasketed the engine and rebuilt the head. New water pump and all that. Everything was new but the bottom end.. As far as the camper goes it was cool but too much for me. My buddy has a ratty aluminum canopy with blue tinted glass that'd match this truck perfect but he won't fuckin sell it. 2 Quote Link to comment
Royal Sierra Posted June 25, 2016 Author Report Share Posted June 25, 2016 Got some sweet hubcaps for my rallies. 3 Quote Link to comment
izzo Posted July 13, 2016 Report Share Posted July 13, 2016 Are you looking for an aluminum canopy for this? 1 Quote Link to comment
Royal Sierra Posted July 17, 2016 Author Report Share Posted July 17, 2016 Are you looking for an aluminum canopy for this? Depends. Whatcha got? 1 Quote Link to comment
Royal Sierra Posted August 29, 2016 Author Report Share Posted August 29, 2016 After much procrastination and a little baby boy being born I figured Id get back to it. Got an engine today and another weber. Tomorrow the swap begins. Hopefully I can drive it off tomorrow. Only wiill have about 5 hours to do it, sounds doable but my luck is always shit. L16 with a W53 head 2 Quote Link to comment
Royal Sierra Posted August 29, 2016 Author Report Share Posted August 29, 2016 2 Quote Link to comment
Royal Sierra Posted August 29, 2016 Author Report Share Posted August 29, 2016 Almost like ive done this before 2 Quote Link to comment
Royal Sierra Posted August 30, 2016 Author Report Share Posted August 30, 2016 4200rpm, no oil... 1 Quote Link to comment
Lockleaf Posted August 30, 2016 Report Share Posted August 30, 2016 That ain't pretty 1 Quote Link to comment
]2eDeYe Posted August 30, 2016 Report Share Posted August 30, 2016 Yummy :sick: 1 Quote Link to comment
Royal Sierra Posted August 31, 2016 Author Report Share Posted August 31, 2016 I got the engine mated to the Trans but now my clutch is very stiff. Slave cylinder moves the fork but I don't think it was this way before. Any ideas.. 1 Quote Link to comment
Charlie69 Posted August 31, 2016 Report Share Posted August 31, 2016 Che the throw out bearing arm is properly on the throw out bearing. Also check the that the throw out bearing arm is properly seated on the ball. Did you clean and re lube the throw out bearing collar and the nose cone of the transmission? Did you clean and re lube the pivot ball and socket on the throw out bearing arm? Do you have the right throw out bearing collar? Is the throw out bearing over adjusted? Quote Link to comment
]2eDeYe Posted August 31, 2016 Report Share Posted August 31, 2016 Did you use a different clutch? There are different throw out bearings, sometimes they can get mixed up. 1 Quote Link to comment
Royal Sierra Posted August 31, 2016 Author Report Share Posted August 31, 2016 Che the throw out bearing arm is properly on the throw out bearing. Also check the that the throw out bearing arm is properly seated on the ball. Did you clean and re lube the throw out bearing collar and the nose cone of the transmission? Did you clean and re lube the pivot ball and socket on the throw out bearing arm? Do you have the right throw out bearing collar? Is the throw out bearing over adjusted? I'll check these when I get home. Same clutch and flywheel. Truck had an l16 when I got it but with a 200mm clutch. It worked fine with the l18 and 225mm clutch that was in it..I'm still using the 225mm..maybe that's part of the issue? 1 Quote Link to comment
Charlie69 Posted August 31, 2016 Report Share Posted August 31, 2016 The throw out bearings are the same the collars the throw out bearings press onto are different lengths. I know that 200mm clutch and the 225 clutch are different lengths. Wayno & Datzenmike both know a lot about this issue. Quote Link to comment
banzai510(hainz) Posted August 31, 2016 Report Share Posted August 31, 2016 he said he putting in a L16 so I assume a l16/18 was in there as he didn't mention a 6 bolt flywheel(like a L20). So same stuff would be used unless the other motor had a roadster pressureplate on there Quote Link to comment
