I'm BLUE Posted January 5, 2014 Author Report Share Posted January 5, 2014 030 by 71240z, on Flickr 031 by 71240z, on Flickr 032 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 5, 2014 Author Report Share Posted January 5, 2014 (rod bearing just dropped off the rod cap..) 033 by 71240z, on Flickr 034 by 71240z, on Flickr yay... 035 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 5, 2014 Author Report Share Posted January 5, 2014 036 by 71240z, on Flickr 037 by 71240z, on Flickr 038 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 5, 2014 Author Report Share Posted January 5, 2014 random pic 040 by 71240z, on Flickr The cranks shaft counterweight (rod side) ends are a little blue ..... #$%# .... So yeah... all the Main and rod bearings are beyond spec (too big) according to plasti-gauge. All bearings indicate they are "Nissan STD xxxxxxxxx" size on the back of each one. Next step .... (Option 1) = out comes the crank for real measuring with micrometer's... then off to machinist for machining (Option 2) = measure my spare crankshaft again.... then take my spare crank that looks to need only a polish to the machinist in place of this one and swap them out. That's all for now working on multiple things at the same time :) BLUE 1 Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 At this point I needed make something to pull the thrust bearing and rear main bearing caps.I decided to make a cheap and dirty ... hokey bearing cap puller.006 by 71240z, on Flickr008 by 71240z, on Flickr010 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 making sure the 7mm bolt fit.012 by 71240z, on Flickrweld into triangle like so020 by 71240z, on Flickr021 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 022 by 71240z, on Flickra 9/32nd bit was used to drill the hole seen above025 by 71240z, on Flickr1" flat-bar026 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 7mx1.00 - 20mm in length + a slightly fatter washer is what i used. (NAPA)028 by 71240z, on Flickr029 by 71240z, on FlickrI love anti-seize. I also made sure to run a tap through the bearing cap threads before this affair.030 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 next install the triangle onto the thrust bearing cap (center one)Also tighten with an 11mm wrench or ratchet wrench.019 by 71240z, on Flickr018 by 71240z, on Flickrnext cut (2) pieces of 24" length ... 1" square tubing like so.,,016 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 next cut a 15" length-ish ... of 3/4" square tubing and place like so in the picture below.017 by 71240z, on Flickrall i did is lift up leveraging the (2) 2ft lengths of tubing ... thrust bearing cap popped right off cleanly. Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 did the same procedure basically to the rear main cap (one more piece of tubing length and a 24" pry bar involved)... came off fairly easily really.034 by 71240z, on Flickr031 by 71240z, on Flickr032 by 71240z, on Flickr033 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 035 by 71240z, on Flickr036 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 037 by 71240z, on Flickr038 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 039 by 71240z, on Flickr040 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 #1 main042 by 71240z, on Flickr#2 main043 by 71240z, on Flickr#3 main044 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 #4 main045 by 71240z, on Flickr#5 main046 by 71240z, on Flickr#6 main047 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 Rear main048 by 71240z, on Flickrpulled it out to clean and mic it... then replace bearings accordingly.049 by 71240z, on Flickr050 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 looks decently good... first impressions051 by 71240z, on Flickrblocks not to dirty.052 by 71240z, on Flickr053 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 my last set of micrometers got "borrowed" , so bought some more.054 by 71240z, on Flickr056 by 71240z, on Flickr057 by 71240z, on Flickr Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 Done measuring with micrometers at this point , and the crank checks out ... at least as far as I could tell (multiple checks on some journals haha)I used a short cut on my coding system since my left gets strained ;)058 by 71240z, on FlickrNow I can order rod and main bearings at this point. Quote Link to comment
Fat510 Posted January 9, 2014 Report Share Posted January 9, 2014 Ohhh, cap puller! lol I was like "WTF...ghetto engine stand?" 1 Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 hahaha .... yeah I probably didn't phrase that correctly .. :D 1 Quote Link to comment
I'm BLUE Posted January 9, 2014 Author Report Share Posted January 9, 2014 Ordered a set of main crankshaft bearings L28et Order Main Rod bearings by 71240z, on Flickr and a set of connecting rod bearings. L28et Order Con Rod bearings by 71240z, on Flickr I already have a full Fel-Pro gasket set for this engine. I also have a new(been sitting around) Beck/Arnley Timing set to install on this already on hand. 002 by 71240z, on Flickr Had been trying to decide honestly if I want to hone/re-ring the engine , but the compression numbers are too good... to dink with yet the time to do so is now if I'm going to do it. I found some Grant piston rings for like $40 shipped or something like that-ish. They've been fine in the past. Looking at other brands as well. I'll have to think on piston rings if at all.. for the standing moment , and I have some time to decide in between while the bearings ship + I work on other stuff non-related. That's it for now BLUE Quote Link to comment
Eagle_Adam Posted January 9, 2014 Report Share Posted January 9, 2014 I freekn love ur pics & ur attention to detail!!!! 2 Quote Link to comment
