lanechurch920 Posted May 24, 2013 Report Share Posted May 24, 2013 My windsheild wipers and the blower in the AC/Heater stoped working at the same time checked fuses under the drivers kick pannel all good is there another fuse pannel? has this happend to anyone elce what could it be? Quote Link to comment
wayno Posted May 24, 2013 Report Share Posted May 24, 2013 Check all your grounds, you may have to remove the dash to do it. Don't just check fuses, they can look good but be bad, replace them. My heater blower quit working, I believe it's the ground, as if I ground any of the wires that control the speed, the blower starts working, I just have not removed the dash to confirm it is a ground issue. Quote Link to comment
db2u Posted May 30, 2013 Report Share Posted May 30, 2013 I had mine going out randomly. The fuseable links that connect to battery cable with the crappy plastic clip connector was not making a good connection. I basically clipped the connector off and replaced it with something I could bolt directly on using the clamp bolt. no issues since then. Might be a place to check. Quote Link to comment
elmerfudpucker Posted May 30, 2013 Report Share Posted May 30, 2013 Check the plug going from the switch to the blower. It is on the passenger side of the heater controls, and goes over the vent tube above your feet. They corrode, that caused the blower to stop on mine. Quote Link to comment
datzenmike Posted May 31, 2013 Report Share Posted May 31, 2013 If your radio and cigar lighter still work then it's the fuse. The 6th one over from the left hand side 15 amp. As suggested replace it or swap the 15 amp fuse from either side of it and try. Quote Link to comment
_A2_ Posted August 14, 2013 Report Share Posted August 14, 2013 Wanted to throw out a word of thanks.Had Wiper and Blower problems, came to Ratsun, searched Forums, found this thread, checked connections at motor over passenger side, per elmerpud's recommendation, found a bad connection, fixed it enough that I could get my inspection sticker.just wanted to say thanks 1 Quote Link to comment
elmerfudpucker Posted August 14, 2013 Report Share Posted August 14, 2013 glad to help! Quote Link to comment
