nismo24096 Posted August 9, 2014 Author Report Share Posted August 9, 2014 inside the bed, to sit flush when closed, and I agree...when i do get a welder Im scared of what I will actually do to the truck...way too many ideas go through my head...lol Quote Link to comment
nismo24096 Posted August 9, 2014 Author Report Share Posted August 9, 2014 quick question for everyone..did the 2 wheel drive model come with a front sway bar? and is it something that can be easily added to my 82 model. Thanks Quote Link to comment
Omelet720 Posted August 10, 2014 Report Share Posted August 10, 2014 I've got a 3/4" stock swaybar on my 84. Cant iimagine that it would be too difficult to add. 2 holes in each frame rail for the mounting brackets and bushings, and one hole in each LCA for the bar end links. Quote Link to comment
Omelet720 Posted August 10, 2014 Report Share Posted August 10, 2014 OR, you could order an aftermarket front/rear kit. Bigger 1" front and adds a rear. Then again, that kit is like 400+, and neither of us is MrBigtanker, lol. Quote Link to comment
nismo24096 Posted August 10, 2014 Author Report Share Posted August 10, 2014 Do you have a link to this 400 dollar kit...I would like to see what its all about...I'm no MrBigtanker...but I have my moments...lol Quote Link to comment
Omelet720 Posted August 11, 2014 Report Share Posted August 11, 2014 I'll see if I can't dig it up. I'm in one of those moments. Full custom front suspension and brakes from Beebani. 1700 for his parts, and then another 450 for JUST the front coilovers. Soooo worth it! Quote Link to comment
Omelet720 Posted August 11, 2014 Report Share Posted August 11, 2014 BAYMMM!! http://www.belltech.com/products/belltech/anti-sway-bars/anti-swaybar-sets-25.html Quote Link to comment
nismo24096 Posted August 11, 2014 Author Report Share Posted August 11, 2014 can anyone confirm that the above kit will in fact fit a 2wd 1982 model Quote Link to comment
Charlie69 Posted August 11, 2014 Report Share Posted August 11, 2014 Your 82 does not have vented rotors. The drop spindles are for vented rotor 720s. Quote Link to comment
nismo24096 Posted August 11, 2014 Author Report Share Posted August 11, 2014 the kit is for sway bars..but thanks for your input. 1 Quote Link to comment
wayno Posted August 12, 2014 Report Share Posted August 12, 2014 You can use drop spindles, but you need to change over to the vented rotors/calipers, I would suggest the 1986 type, that way you will not need spacers. Here is a set for a reasonable price. http://www.ebay.com/itm/Street-Edge-2-Drop-Spindles-83-97-Nissan-720-Hardbody-D21-/271554796179?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3A720&hash=item3f39ed5a93&vxp=mtr Quote Link to comment
nismo24096 Posted August 12, 2014 Author Report Share Posted August 12, 2014 No offense to you wayno or charlie, but if you actually read what me and omelet were talking about or follow the link you would see that we are discussing SWAY BARS...not drop spindles, now granted that all anyone thinks about when they see BellTech is the drop spindles, but that was not the question asked. but again thanks for the input..i surely know all about drop spindles now...lol Quote Link to comment
Omelet720 Posted August 13, 2014 Report Share Posted August 13, 2014 I fucking loled. Try clicking the link, hehehehe. ;) It says it's for an 80 and up, so I can imagine it would. If you bought it and it didn't fit your truck when their website says it does, then you should be able to get your moneys back. Quote Link to comment
Omelet720 Posted August 13, 2014 Report Share Posted August 13, 2014 WELL derp. It says 83 and up, but I don't see why it wouldn't. The frames are the same width and the LCA's should be the same. If anything you could modify it to work. As for the rear, you're going to have to do some fabbing, because we don't have anywhere to mount one stock. Quote Link to comment
nismo24096 Posted August 13, 2014 Author Report Share Posted August 13, 2014 ok make a little progress today before the heavy rains started.. the 4x4 leafs dropped the truck 2inches with the bed off. but because its stiffer with the bed on its more like the 1.5 inches everyone talks about. ordered me some air shocks to install so i can air it up when i want to carry something and not worry about bottoming out. also i finally came across some new replacement tail light buckets on ebay.. been looking for some forever but normally only find the 620 ones...well two days ago they where on there...so I should have them tomorrow. no more rusted out buckets...also when I replaced the leafs, the offset wheel issue when away. now its the same side to side. so it seems the leaf packs were the issue.again..this all makes me happy as hell. now to continue with the body work to get it a little straighter then on to a final primer job and later paint.. now i need to lower and camber the frontend some...waiting on my poly bushings to get here, I put the backs in today and they were super easy.did black so they don't stand out. Quote Link to comment
nismo24096 Posted August 14, 2014 Author Report Share Posted August 14, 2014 More goodies came in the mail today...new inner and outer tie rods and poly bushings for the frontend...as well as the air ride shocks for the rear. Quote Link to comment
Omelet720 Posted August 15, 2014 Report Share Posted August 15, 2014 Very nice. I noticed a huge improvement with my poly leaf bushings. WAY less side to side play. And a much better ride with 4x4 springs. Gives it a nice rake too. I like your airshocks. I thought about getting a set for the rear of my truck, but I decided to use qa1 coilovers with load control bags for when I'm haulin' or towing. Can't wait to see your final paint job man. Quote Link to comment
nismo24096 Posted August 15, 2014 Author Report Share Posted August 15, 2014 OK so here is my take on some repo rear light buckets that I got off ebay this past week, first off they are cheap repos and with that the metal is a little thinner than factory and the forming around the edges of curves is more of a crinkle than a straight line, now granted most of this you can not see as its where the metal falls outside of the press mold, they were shipped in a unpadded box and were a little tweaked from our great ups shipping service. but with some hammer and dolly work and some pliers I was able to get them to fit fairly well. below are the after pics sorry i didnt take any of them right out of the box. which they come bare metal..no coating at all primer or otherwise. and I picked up my new mufflers that I plan to use.... These bad boys retail for around 600 bucks new....these have like a months use on them....they are for a hayabusa but I plan on mounting them on both sides of the tag in between the tail lights, they should be pretty cool looking and I hope sound kinda cool.. we shall see.. but for the price I got them for I could not pass on them. worst case is I resell them for a profit....but I think I will keep them. Quote Link to comment
datzenmike Posted August 16, 2014 Report Share Posted August 16, 2014 quick question for everyone..did the 2 wheel drive model come with a front sway bar? and is it something that can be easily added to my 82 model. Thanks The 720s all had a front sway bar. OR, you could order an aftermarket front/rear kit. Bigger 1" front and adds a rear. Then again, that kit is like 400+, and neither of us is MrBigtanker, lol. On a properly 'sorted' vehicle the handling should be more or less neutral. On a hard enough corner the front and rear tires should loose traction at the same time and begin sliding out. In NASCAR terms neither 'loose' nor 'tight'. All vehicles are designed with a slight understeer ('loose') built in. This is considered the easiest to recover from by just letting off the gas and hitting the brakes. Adding a thicker front sway bar without considering the implications of doing so will upset and surprise you one day in rain, snow or any change from normal traction you are not ready for.. A thicker stiffer sway bar will definitely do more than limit 'sway' or tipping to the outside on turns. A stiffer bar on the front will increase the truck's understeer making it harder to recover from it. If adding more front stiffness it should be balanced by increasing or adding a rear sway bar. There are other things you can do to add balance between loose and tight, a rear bar is only one. Quote Link to comment
nismo24096 Posted August 16, 2014 Author Report Share Posted August 16, 2014 Ok after trying a few different options for a front air dam, I think I like this one, I still plan to make my own out of fiberglass in the future or metal, but for now I think I like this look. dont mind the tape I need to get the brackets to mount everything up.. enjoy..... Quote Link to comment
Charlie69 Posted August 16, 2014 Report Share Posted August 16, 2014 This is what a stock 720 looks like. It is nice and clean and made of steel.If you lower the front much at all then you will have to shave the plastic one. Quote Link to comment
nismo24096 Posted August 16, 2014 Author Report Share Posted August 16, 2014 I only plan to go maybe an inch lower in the front if that. and its no where as low as my old 240 was. so it will be fine, and fyi the 80-82 have a metal one much the same shape as yours it just does not protrude quite as much. Im also planning a different style bumper that stock on mine, once I source the materials and get it all cut and installed I will surely post the pics up. Quote Link to comment
nismo24096 Posted August 16, 2014 Author Report Share Posted August 16, 2014 Charlie, you truck looks good man, where did you get the hood bra? still sanding and fixing little dents on mine but its getting closer...lol Quote Link to comment
Omelet720 Posted August 18, 2014 Report Share Posted August 18, 2014 Okay, I had to lol. That's DREWSDIME's dime. http://community.ratsun.net/topic/55951-720-daily-driver/?fromsearch=1 It's funny because his truck has been featured on Japanese Nostalgia car. Kind of in love with his rTuck. My 84 has the same lip, and honestly, I kind of wish I had the same valence as you. (I know I COULD put in the early valence). The earlier one would make it a lot easier to make a horizontal lip. That being said, I like that lip you've got there! I think if you keep it black or body color, and fill that one hole of to the side with a fog lamp, it would look really awesome! Quote Link to comment
nismo24096 Posted August 18, 2014 Author Report Share Posted August 18, 2014 Yeah the extra opening on the drivers side, not sure if Im gonna just cover it with a front licence plate bracket to put my tag... or put the tag on the other side to balance it out.. not decided at this point. and as for the big openings in the bumper Im thinking of making some cool fog light or driving light pods to go in there. and as for the front bumper. im still planning on going with a split bumper design like the old school camaro has. Quote Link to comment
