1979 Datsun 210/B310 Clutch Replacement Guide
I've found this step by step written out on another ratsun post. It was for a 240SX... So, I'd like to make sure it is still accurate process for the Datsun 210/B310. If there is anything to add to this list or a different way for the 1979 Datsun 210/B310. Please reply.
Guide: Step by Step to Replacing Clutch.
1.) Drain transmission and remove.
2.) Remove pressure plate from flywheel.
3.) Remove and replace pilot bushing in crank.
4.) (Optional) Remove flywheel and have resurfaced and/or lightened - change rear main seal - replace flywheel.
5.) Hang new clutch friction disc on flywheel using alignment tool.
6.) Install new pressure plate.
7.) Remove throwout bearing from carrier on transmission input shaft and replace with new bearing.
Side Notes:
      - Lightly wipe some lithium grease on the input splines and wipe off with a rag.
      - Clean and re-grease the pivot arm contact surfaces, ball socket, and slave cylinder push rod surfaces with lithium grease.
Thanks!
Adam
  • Replies 17
Yep easy as 1234567..Add in some swear words,a few wrenches,sockets,some more swear words.
your new to this?
Maybe a bloody knuckle or 3 and some more cuss words??
Haha. Awesome. Yes, very new. Looking forward to it now. Thanks for the confirmation. :thumbup:
Guest 510kamikazifreak
Not really.
Safety first :sneaky:
Eye protection, you don't want 35 yr old dirt and grime in your eyes
:rofl:
That goes without saying,I have eye protection 24-7 :rofl: (4 eyes) :w00t:
8. installation is in reverse order of removal.
9.  After 8.
Beer
one could have beer during too, but one beer usually leads to another,and another,and soon,you forget how things went back together
9.  After 8.
Beer
True , it also thins your blood so you may bleed out. However, you won't feel the pain of the transmission landing on your chest!
its like a double jeopardy :rofl:
