Janksun Posted March 28, 2013 Report Share Posted March 28, 2013 I'm putting my truck up for sale because I want to save up for a 510. So here goes 1975 Datsun 620 Stock truck Removed most of the smog equipment Runs good, sometimes runs hot but probably because I took the fan shroud off, I'll reinstall and drive around an see what happens. The brakes are wonky, they work but not as well as they should Sometimes it will idle and sometimes it won't, idk what the problem is There's a lot of rot in the rockers and cab corners, I have replacement panels you can weld in. It's a 4 speed The odometer says it has close to 40,000, I know for sure it has rolled over once, but idk about twice. Newer tires in the rear. Rattle can paint I bought this truck from izzo and drive it all the way to California, it started overheating and turned out it was the radiator, replaced that with a used one and it does ok, should be taken to a shop and get checked out. Heater works. Most lights work. LED dash lights. Also has an aftermarket radio that barely works, only plays CDs. I got it for free lolz And two nice speakers This is a daily driver but I only drive in town. Good little truck. Price: $1000 firm Or trade for a 510 4 door or wagon of equal trade If nobody wants to buy or trade I'll just fix all the rot, paint, mechanical issues and turn this into a nice 620 and then the price will go up! Located in Ripon, California Hit me up! Link to comment
