Door panel ideas
  • Please log in to reply
26 replies to this topic
#1 XXL
XXL
  • Senior Member
  • PipPipPipPip
  • 528 posts
Posted 25 March 2013 - 05:53 PM
Now that the seat is done, it's time to turn my attention to the door panels and kick panels.
Here's the stock panel...
:pirate:  Scrimpin' aint easy
#2 XXL
XXL
  • Senior Member
  • PipPipPipPip
  • 528 posts
Posted 25 March 2013 - 05:58 PM
Here are a few quick and dirty mockups of some ideas... don't worry about the colors.  I spent about 10 minutes in pshop on them.  The colors are already set by the materials I used on the seat.
"Leaf" --
and "slate" --
In each of the below, I moved the lower color separation line from the horizontal as it is on the stock panel, to a slight angle that roughly matches the seat bottom angle.  I think this makes more sense visually.
For the green insert portion, I will likely do a very thin pleat that mimics the pleat of the seat (only no more than 1/8" padding.  I don't want a pillowy door).
On this one, I took lazy to a new level and didn't bother to work it up in pshop.  I just penciled in the arc.  the idea is to have the pencil shaded part to be one piece with the other two gray strips.  The green would look more like a typical insert in a door.  A couple of thoughts, though... 1) it seems to beg for a traditional arm rest in the green part, and 2) I'm not sure the curve fits with the design of the truck itself.
Comments?  Blank stares?  Ideas?
#3 boxboy
boxboy
  • Senior Member
  • PipPipPipPip
  • 459 posts
  • Cars:1968 520 pickup
Posted 26 March 2013 - 02:37 PM
I don't have any suggestions, but I will say that you should get some good money for those original panels.  I went through great trouble to preserve them and get them looking nice.  I replaced the actual masonite panel as they were warped from years and moisture.  But the skins are in remarkable shape.  Nice to watch your progress!
#4 XXL
XXL
  • Senior Member
  • PipPipPipPip
  • 528 posts
Posted 26 March 2013 - 05:17 PM
I won't be molesting the original panels.  They will be stored for posterity.
#5 highdesertdatsun
highdesertdatsun
  • Senior Member
  • PipPipPipPip
  • 325 posts
  • Cars:63 C10 66 520 68Xr7 68 goon 87K5 91V3500
Posted 27 March 2013 - 06:45 AM
i gota go with the stock configuration or two tone top and bottom with strait line.
 but if you look the stock door panel seems to match the body lines on the outside of door.
i think I like stock style best . the others are cool just kinda remind me of old school
vw stuff . you gotta put the  Santa Cruz sticker on it then.
I will have mine made  like your stock ones , thanks for the pic because I had no Idea
what they should look like. i also got my seat design from one  Wayno posted on your seat
design. my colors wont be stock though hunter green and black . cant wait to see how it comes out .
"It's the bizarre idiots that act smart."
#6 alabama_lowlife
alabama_lowlife
    Hall Monitor
  • Members
  • PipPipPip
  • 180 posts
  • Cars:08 Altima, 97 Nissan p/u, 93 Nissan 300zx, 89 Nissan p/u, 1970 Datsun 521
Posted 31 March 2013 - 02:00 PM
I kinda like the stock design over the other choices. Maybe some 1" pleats worked into it?
#7 XXL
XXL
  • Senior Member
  • PipPipPipPip
  • 528 posts
Posted 31 March 2013 - 05:21 PM
Thanks.  In general, I do like the angles of the 3 modified examples I posted above, but I think you're right about the stock design... it really lends itself more to the simple nature of the truck.  The angles and curves are too "progressive" for a stock truck (perhaps if I was doing buckets, console, stereo, and a bunch of gauges... but not with the stock lines).  So... I agree.  I think I need to stick with the stock panel lines.  And I was actually thinking about very thin stitched pleats to play off those on the seat.  What I'm leaning toward at the moment is, rather than go with the 3 strips, just doing 2 strips of color... combining the top strip and main body into a single color (leaf green), and then the bottom strip in the slate gray.  That will give me a little more of the green on the panel, so it will look less like a racing stripe (which is why I had contemplated the angle before-- so it wouldn't look like a racing stripe down the door).
Now... what about the kick panel?  Do I extend the 2-color pattern onto the kick panel, or just make it a single color?
#8 4perrev
4perrev
  • Senior Member
  • PipPipPipPip
  • 877 posts
  • Cars:1972 Datsun 521, 1972 2 Door 510, 1971 4 Door 510 & some Euro cars.
Posted 31 March 2013 - 07:28 PM
I like the colors you picked, but I also like the original 3 strip pattern.
If it eats gas and blood type is measured by weight, it's good by me!
1972 521 Resto http://community.ratsun.net/topic/52247-my-first-datsun-resto-1972-521/page-1
1972 510 Resto http://community.ratsun.net/topic/62863-the-dime-finally-realized/
#9 DatWifey
DatWifey
    Dat Petty
  • Senior Member
  • PipPipPipPip
  • 1,678 posts
  • Cars:'66 SPL311, '71 521 (x2), '72 510 4-door, '85 Maxima goon
Posted 01 April 2013 - 03:38 PM
As stock as the overall truck is, personally, I would keep with the pseudo-stock look of similar styling on the panels.
Our panels in our 521 were covered in a plain black vinyl when we got it, as well as the seat with a basic faded canvas, so I re-did them at the same dimensions of the stock panels.  My initial go-around, I did a piping seam with 1/4" foam, and it sucked.  The window roller was harder to wind, and kept hitting the piping.  So, I re-did them again with a super thin layer of foam (maybe 1/16"), just to hide any indentations from the panel clips, and it was MUCH better.  And I just did the kick panels to match the stock color, and on the 2nd go-around on the panels did the center strip to match the seat.
With padding and piping
2nd try with less padding and no piping, just regular seams
But, if you do go for something different, Madness did some badass panels a while back that I really liked.  (you can see his post of how he went about them here in his first post)
#10 XXL
XXL
  • Senior Member
  • PipPipPipPip
  • 528 posts
Posted 01 April 2013 - 03:53 PM
Thanks for the insights and the pics.  I see where the piping (or any other "thick" material) would cause a problem with the crank.  I'll definitely keep that in mind.  I do like your second panel better as well... hmmm...
#11 XXL
XXL
  • Senior Member
  • PipPipPipPip
  • 528 posts
Posted 26 April 2013 - 06:21 PM
Last weekend I pulled the door panels off the truck.  I was expecting them to be original, but it looks like someone scavenged an old write-on board to make new panels, then covered them with the original material pictured above.  I was planning to use the "original" panels as a template to make new ones out of 1/8" ABS plastic sheet, then store the old ones for posterity.  However, since they're not original, I decided to reuse them.  I stripped off the material and am setting that aside in case someone is looking to restore their panels to factory look (PM me if interested :) ).
For the new covers, I'm going to keep the stock lines as others have suggested.  I'm doing the leaf green on top and bottom, and the slate gray stripe through the middle, with a French seam stitch where the pieces connect to keep things flat.  That will all be backed by an 1/8" foam, and then wrapped onto the panel.  The vinyl is at the upholstery shop now.  He's got a bit of backlog, so it will be a couple of weeks before I can get them wrapped and back on the doors.  Pics to follow.
#12 XXL
XXL
  • Senior Member
  • PipPipPipPip
  • 528 posts
Posted 08 May 2013 - 12:20 PM
Door panels are done, and back on the truck.
#13 XXL
XXL
  • Senior Member
  • PipPipPipPip
  • 528 posts
Posted 08 May 2013 - 12:22 PM
I used a 1/8" padding to keep the panels thin, but the door handles were still rubbing slightly so I relieved the back side of the handles about 3/16".
Before--
and after--
#14 XXL
XXL
  • Senior Member
  • PipPipPipPip
  • 528 posts
Posted 08 May 2013 - 12:42 PM
If anyone is looking for the factory panel covers for a resto, please PM me.  Mine are in VERY good condition and for sale.
#15 Jackson311
Jackson311
    Advanced Member
  • Members
  • PipPipPip
  • 84 posts
  • Cars:2003 350z - 1970 spl311 (x2) - 1972 510 2dr ka
Posted 08 May 2013 - 12:55 PM
love your color combo.
you have very nice taste!
#16 JoeCool
JoeCool
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 2,329 posts
  • Cars:1980 Datsun 720... SOLD. Now own a 2002 Nissan Frontier XE. Crew cab, 4x4
Posted 08 May 2013 - 03:15 PM
WOW! That interior is turning out great! I see just one problem... if you keep making your truck look nice, we will be forced to ask you to leave. This is RATsun. We have ratty rides here! :P
*"If it falls off, it doesn't matter!" Tom Magliozzi of Car Talk
#17 XXL
XXL
  • Senior Member
  • PipPipPipPip
  • 528 posts
Posted 08 May 2013 - 03:42 PM
Thanks.  I'm leaving the surface rust on the bed floor ;)
#18 DatWifey
DatWifey
    Dat Petty
  • Senior Member
  • PipPipPipPip
  • 1,678 posts
Posted 08 May 2013 - 04:05 PM
That looks clean!  Good choice with the pattern and stitches used :thumbup:
#19 thisismatt
thisismatt
    Senior Damon
  • Senior Member
  • PipPipPipPipPip
  • 7,942 posts
  • Cars:'71 521, '69 521 donor
Posted 08 May 2013 - 04:11 PM
Nice work - looks great!
I'm your huckleberry.
One jump ahead of the lawmen
That's all, and that's no joke
These guys don't appreciate I'm broke
#20 highdesertdatsun
highdesertdatsun
  • Senior Member
  • PipPipPipPip
  • 325 posts
Posted 08 May 2013 - 05:55 PM
Big pimpin! They came out sweet . Hardly any room
for foam . Note taken. I hope to afford mine soon!
The paint on door. Original? Looks mint.
