H-165 Disc Brake axle/differential complete
  • Replies 21
This is a coil spring axle assy but with some trimming and welding, spring mounts can be added and it would fit a 710 or B-210.
Will fit the 210 as is I think.
The disc brake axles will fit the 710, I tried it on my goon.
Whoops I meant to mention the suspension mounting.
As always very good info (learned something) and Thankyou datzenmike !
In the S110 (200sx) only the '80 and '81 had the H-165. Auto and 5 speeds were 3.700 ratio
Other (non disc brake H-165) year and makes had...
'77-'79 S10 (200sx) 5 speeds were 3.889 and autos were 3.70
'78-'80 L20B equipped A10 (HL510) 4/5 speeds and autos were 3.545
'80-'81 Z20S equipped A10 (HL510) 4/5 speeds and autos were 3.364
The '74 710 (L18) automatics had 4.11s in them, standards were 3.889. After '74 they were all L20B with 3.70.
This is for an H-165 and I see you have a 510 goon that had H-190s in them. If looking for an H-190 around 3.545 check out the Maxima goon. Even the side gears are the same 23 tooth axle spline as the 510.
I have the disc brake axles from an '80 200sx and they fit the 710 perfectly. Even the E brake pulls across the back and can be modded to fit. I gave the caliopers away but have some '02 Altima rear calipers that I can make work on ZX rotors. i think.
  • 3 weeks later...
I guess no one with a 710 want disc brakes... cause where all lame glws
You would have to cut away the coil spring perches and the control arms and weld on leaf spring mounts. Or you could just swap the axles into a 710.
