highdesertdatsun Posted April 13, 2013 Author Report Share Posted April 13, 2013 el dizzy failed so Im putting points back in untill I find a L engine dizzy . then Ill swap the dizzy drive with A engine shaft I i think it will be bolt in . no mod to bracket or anything . Quote Link to comment
wayno Posted April 13, 2013 Report Share Posted April 13, 2013 You cannot just bolt on electronic ignition to a J block, you have to make it out of an original distributor and a matchbox, mike did it in his thread, it's on the first page how he did it. http://community.ratsun.net/topic/393-mklotz70-nl320/ Some others have adapted a pectronics setup I believe onto a stock distributor, but I cannot recall which thread it was done in. Quote Link to comment
JoeCool Posted April 13, 2013 Report Share Posted April 13, 2013 That's a nice looking truck! 1 Quote Link to comment
highdesertdatsun Posted April 13, 2013 Author Report Share Posted April 13, 2013 thanks joe cool wayno the drive gear roll pin hole is incorectly spaced on the A engine dizzy . the thread that shows it being installed is using a L engine dizzy i think thats my only issue with making it work. in that thread they had to mod. the advance plate but on a A engine dizzy its clocked just right . only shaft issue. so a shaft from a L engine dizzy is my new quest also a vacum advance pod with only advance and no retard because the dual pod one is longer and may contack head/block if clocked as stock one was designed. I read that thread when you advised it last. it got me started. im closer thanks . i will post it when i figure it out. I had i all apart today. but I gotta drive this thing today. el dizzy or points its gonna move on its own power. may not stop as of yesturday my drivers rear wheel cylinder started leaking . thats next ha ha Quote Link to comment
highdesertdatsun Posted April 13, 2013 Author Report Share Posted April 13, 2013 I guess i could go petronics but I trying to stick with matchbox if poss. Quote Link to comment
XXL Posted April 13, 2013 Report Share Posted April 13, 2013 Some others have adapted a pectronics setup I believe onto a stock distributor, but I cannot recall which thread it was done in. I recently did a Pertronix swap. Simple install and so far, so good... http://community.ratsun.net/topic/52578-anyone-recommend-converting-to-electronic-ignition/ Quote Link to comment
highdesertdatsun Posted April 13, 2013 Author Report Share Posted April 13, 2013 i remember like it was yesturday. your petronics install that is . OK i drove it holy shit. it runs good real good for fuck sakes. has a slight rattle from what im guessing is timming chain after revs. not anything major though. If any body knows the size of rear wheel cylinders im gonna get a kit to rebuild my new found leaker. I also need rear blocks 2 inch to drop it just a bit. the torsion bars adjuster bolts are at two diff lenths so i guess I must turn one of the bars to make that right then lower it a little. when braking i hear the metal to metal where rubber control arm bush is toast. rebuilt my trans mount with urathane its working great. I love that stuff. Quote Link to comment
highdesertdatsun Posted April 15, 2013 Author Report Share Posted April 15, 2013 oic Quote Link to comment
highdesertdatsun Posted April 15, 2013 Author Report Share Posted April 15, 2013 ad thenparked in front of my dd the SS MINOW.it drove out of shop under its own power .YES !!!and I found a 72 620 with a tach to buy my daughter for her first car/truck. Quote Link to comment
highdesertdatsun Posted April 15, 2013 Author Report Share Posted April 15, 2013 just had r glass tinted Quote Link to comment
Charlie69 Posted April 16, 2013 Report Share Posted April 16, 2013 Here is the pinout for the Instrument cluster PC board. 1 Quote Link to comment
Charlie69 Posted April 16, 2013 Report Share Posted April 16, 2013 I am using a later model steering wheel that looks crappy on the wheel part so I am going to wrap it with leather. This will help with the heat from the AZ summer sun. Quote Link to comment
highdesertdatsun Posted April 17, 2013 Author Report Share Posted April 17, 2013 finished tint . limoair box installed Quote Link to comment
highdesertdatsun Posted April 30, 2013 Author Report Share Posted April 30, 2013 moar loarmoar loar Quote Link to comment
highdesertdatsun Posted April 30, 2013 Author Report Share Posted April 30, 2013 and then Quote Link to comment
highdesertdatsun Posted April 30, 2013 Author Report Share Posted April 30, 2013 results of three inch blocks and adjusting t bars Quote Link to comment
highdesertdatsun Posted April 30, 2013 Author Report Share Posted April 30, 2013 did brakes all around and replaced drivers front wheel studsand upper outer control arm bushings Quote Link to comment
Charlie69 Posted May 1, 2013 Report Share Posted May 1, 2013 looking good. Have fun adjusting the reat brakes with the blocks in. 1 Quote Link to comment
highdesertdatsun Posted May 1, 2013 Author Report Share Posted May 1, 2013 Your so right. The new shoes require frequent adjustment until seated and even my special tile tool that works like made for truck barely works. If the adjuster wasn't freshly cleaned and lubed it would be a bitch. Quote Link to comment
highdesertdatsun Posted May 1, 2013 Author Report Share Posted May 1, 2013 I freaking scored!! I was looking for nice carpet stuff to install in Nikki.I remembered I have a account w a trim place. the dino liner ,mat and carpetonline was expensive. So I called Phoenix trim & supply co. to check on pricesof loopcarpet black and foil backed liner matt .I spent 169.44 total .shipped.i bought 3 yards of 72" black loop carpet "nice stuff" 4 black medium heal pads.some may want small because its like a floor matt. but im gonna bring it up firewalla little. also 5 yards of 27 oz s/s foil pad 48" , the binding for edges of carpet black1.25 inch black 10 yards. and last but not least a bottle of autocare l/p cleaner.32ozthe cleaner is realy good for old interior stuff .makes old shit look new. i dont knowwhat it is but is hardcore wholesale only. anyways Im going to recarpet Nikki andDaughters 620. Ive never done this before any sugestions ? bring em. thanksoic wholesale only . use someones biz lic # phx trim & supply 1-800-369-5084 Quote Link to comment
XXL Posted May 2, 2013 Report Share Posted May 2, 2013 Take lots of pics of your work. I need carpet as well, but I'm not prepared to take on actually sewing in binding and foot pad, so I'll have to hire someone to make a kit for me. Maybe you??? ;) Quote Link to comment
highdesertdatsun Posted May 2, 2013 Author Report Share Posted May 2, 2013 The kid that works for me used to help do aircraft interiors. Where stuff has tourqe specs and all kinds of other regs . We are starting Friday . He owns a souped up sewing machine. Well see what he can do. Quote Link to comment
highdesertdatsun Posted May 3, 2013 Author Report Share Posted May 3, 2013 we are using spectra 8lb test for the thread because I want it strong!! maybe overkill but. Quote Link to comment
highdesertdatsun Posted May 4, 2013 Author Report Share Posted May 4, 2013 Spectra failed now we have HD nylon thread. Spectra to limp for machine . Quote Link to comment
