Messi720D Posted March 15, 2013 Report Share Posted March 15, 2013 yo people i got some 18in stock steel titan rims and plan to put them on my 720 what size tire should i run also just did a 2in drop and just want to get an idea on tire size i plan on going lower after the install i possible thanks Link to comment
DREWSDIME Posted March 15, 2013 Report Share Posted March 15, 2013 You might have better luck posting in 720 section Link to comment
datzenmike Posted March 15, 2013 Report Share Posted March 15, 2013 From 185/50R18 to 200/50R18 depending on width. (seven to eight inches) I wouldn't get the rims first and try to make the truck fit them but make the rims fit the truck. What's the offset on these rims? They may stick out past the fenders right now and this will make lowering impossible. You want rims with similar offset as the stock rims so the tire stays inside (tuck) the fender. Link to comment
