wickedminded420 Posted March 13, 2013 Report Share Posted March 13, 2013 It has the L18 I believe it is stock for the truck but every where I Go they say L16 so I'm in need of a oil change and don't know the specs cause my manual hasn't came in so any help would be much appreciated Quote Link to comment
DatDoug Posted March 13, 2013 Report Share Posted March 13, 2013 Congrats on the purchase. 10w-30 or 40 will work fine. Dont use Penzoil or Quaker State & dont use fram oil filter. Now get some PICS up of your new truck! :poke: Quote Link to comment
wickedminded420 Posted March 13, 2013 Author Report Share Posted March 13, 2013 I have a 1973 datsun 620 pickup it runs perfectly but is in need of a oil change and I don't have a manual yet so it has the L18 with only 107,xxx miles so if you guys can tell me the specs for the amount of oil that goes in I'd appreciate it I just got this car Quote Link to comment
kelowg Posted March 14, 2013 Report Share Posted March 14, 2013 4-5 qts,10-30 or 20-50 Quote Link to comment
420n620 Posted March 14, 2013 Report Share Posted March 14, 2013 1970-1973 and 1975-1980 with filter change ~~~~~~ 4 1/2 qt without filter change ~~~ 4 qt 1974 w/ filter change ~~~ 5 1/8 qt w/o filter change ~~ 4 3/8 qt I fill the oil filter with 1/2 qt then spin it on. That way it takes less time to fill the filter when you start the motor up, so it gets oiling to the top quicker. Make sure you check the dip stick to make sure it up to the mark, before starting. Quote Link to comment
bonvo Posted March 14, 2013 Report Share Posted March 14, 2013 all l series 4 bangers hold the same amount of oil i personaly wont run anything other then castrol in any of my engines and i steer clear of fram just go to a parts house and tell them you need a filter for the truck they all use the same filter Quote Link to comment
bonvo Posted March 14, 2013 Report Share Posted March 14, 2013 your in vacaville go to the kregan (oreillys or whatever there called now) next to the walgreens at the intersection of peabody and alamo ask for dan he will help you out he has dattos Quote Link to comment
wickedminded420 Posted March 14, 2013 Author Report Share Posted March 14, 2013 Sounds kinda messy filling it halfway but ill try it and also I have to get on level round before I do all this thanks I just got this pickup and the manual is taking forever lol Quote Link to comment
420n620 Posted March 14, 2013 Report Share Posted March 14, 2013 nope, just don't tip it upside down. but if you do get sloppy, have a rag close by. Quote Link to comment
datzenmike Posted March 14, 2013 Report Share Posted March 14, 2013 Spend about $5-$7 on a good oil filter. NAPA house brand or Wix are still good.15W40 Shell Rotella or Chevron Dello 400 still have a reasonable amount of ZDDP in their formula. Many, if not most, oils today don't protect out 'flat tappet cams' near enough because the ZDDP levels have been dropped to 'protect the environment' and because most engines today use roller rocker cams. Tell the NAPA guy you want an oil to protect your flat tappet cam, he'll know.Look on the door jam for the build date. If between Oct.'73 to Sept. '74 it should have an L18 in it. Earlier would be an L16, but as Bonvo said they are pretty much identical except for some internal parts. After 40 years it may have had several engine swaps so if you want to know for sure look on the top edge of the block where it meets the head just behind the dip stick handle. It's stamped into a flat boss on the block. 1 Quote Link to comment
racerx Posted March 14, 2013 Report Share Posted March 14, 2013 congrats. welcome to the Datsun dimension. Quote Link to comment
datzenmike Posted March 14, 2013 Report Share Posted March 14, 2013 Yes I see you already have a post started about your oil so I just merge these two posts together. Quote Link to comment
thisismatt Posted March 14, 2013 Report Share Posted March 14, 2013 I used Chevron Dello 400 during my last change and it made a noticeable difference (quieter). I always just use a Motorcraft (Ford) FL-1A filter - large, good, and cheap. Quote Link to comment
racerx Posted March 14, 2013 Report Share Posted March 14, 2013 yep..read that motorcraft Fl-1a is just like Puralator which is also supposed to be good. Next oil change no more Fram...hear and read to many bd things. Good to hear FL-1A can be used for Datsuns, same one for my 65 Mustang... Quote Link to comment
Javin Posted February 11, 2015 Report Share Posted February 11, 2015 Spend about $5-$7 on a good oil filter. NAPA house brand or Wix are still good. 15W40 Shell Rotella or Chevron Dello 400 still have a reasonable amount of ZDDP in their formula. Many, if not most, oils today don't protect out 'flat tappet cams' near enough because the ZDDP levels have been dropped to 'protect the environment' and because most engines today use roller rocker cams. Tell the NAPA guy you want an oil to protect your flat tappet cam, he'll know. Look on the door jam for the build date. If between Oct.'73 to Sept. '74 it should have an L18 in it. Earlier would be an L16, but as Bonvo said they are pretty much identical except for some internal parts. After 40 years it may have had several engine swaps so if you want to know for sure look on the top edge of the block where it meets the head just behind the dip stick handle. It's stamped into a flat boss on the block. You mention those two oils specifically, but aren't they both for diesel engines? Will that cause any issues? Quote Link to comment
dr.feltersnatch Posted February 11, 2015 Report Share Posted February 11, 2015 Nope. I run dello 400 and it works just fine. Quote Link to comment
Lockleaf Posted February 12, 2015 Report Share Posted February 12, 2015 Diesel oils are high in products that can damage catalytic converters from within the last few years. Other than that they are excellent oils manufactured to take serious abuse. I run delo in my 720 and my pathfinder and in my 70s and 80s Honda motorcycles. I love that stuff. You are not only perfectly safe running those oils, because of the zddp, you're actually better off running them. Quote Link to comment
Javin Posted February 12, 2015 Report Share Posted February 12, 2015 Diesel oils are high in products that can damage catalytic converters from within the last few years. Other than that they are excellent oils manufactured to take serious abuse. I run delo in my 720 and my pathfinder and in my 70s and 80s Honda motorcycles. I love that stuff. You are not only perfectly safe running those oils, because of the zddp, you're actually better off running them. Since I am running a catalytic converter in my truck, maybe I will stick to something else? Quote Link to comment
Lockleaf Posted February 14, 2015 Report Share Posted February 14, 2015 No reason. The concern is for cars manufactured recently and their catalytic system. It doesn't matter when the cat was built, because you're either using universal which have fewer catalysts or factory from a time it didn't hurt anything. Unless you install a 2015 frontier exhaust, you don't have anything to hurt. I assume you came here for expert advice, so take it. These guys are aware a 70s datsun has a cat. We're all telling you it doesn't matter, that delo is the best. I understand you want to the best you can for that old beast. Listening to guys datzenmike is the best you can do for it. Quote Link to comment
